Dale Jarrett wins
Elwood
Congratulations to Dale Jarrett.
I'm not a RYR fan, but I do like Jarrett alot better than Buch, so I was happy.  I just hated to see Rusty run so awesome all day and then fall off, but I figured he would.  The early dominate car usually falls off at the Rock.
What about Jr.?  He was involved in 5 of the cautions today, 2 of which he just spun out all by himself.  Rough day, I hope they get on track next week.
LOL did you notice the top 10 , 6 of them are ford and 2 dodges
GM didnt even show up today  :wtf:  :rolleyes:
1 9 #88 Dale Jarrett  Ford UPS 180/5 393 Running
2 27 #97 Kurt Busch  Ford Rubbermaid 175/5 393 Running
3 18 #17 Matt Kenseth  Ford DeWalt Power Tools 170/5 393 Running
4 6 #32 Ricky Craven  Pontiac Tide 165/5 393 Running
5 7 #42 Jamie McMurray * Dodge Texaco/ Havoline 155/0 393 Running
6 8 #2 Rusty Wallace  Dodge Miller Lite 160/10 393 Running
7 3 #6 Mark Martin  Ford Viagra 151/5 393 Running
8 37 #48 Jimmie Johnson  Chevrolet Lowe's 142/0 393 Running
9 11 #38 Elliott Sadler  Ford M&M's 138/0 393 Running
10 1 #77 Dave Blaney  Ford Jasper Engines & Transmissions 139/5 393 Running
:nono:
Maybe GM should just drive by the track next time  :lol:
GM didnt even show up today  :lol:  :rolleyes:
:nono:
Is that supposed to be funny?
:wtf:
GM just had bad luck today, they'll be  back at Las Vegas.
Personally, I'd rather would've seen Busch win it than Jarrett.
What I REALLY wanted to happen was everybody infront of Martin to run out of gas. :rolleyes:
I hate to see all the old tracks go away but after that race, I won't mind at all
I couldn't bear to watch it...  good thing UK was playing or I would have taken a nap.
I would have rather seen busch or rusty win instead of jarrett,  I hope he does race that brown truck so everyone can pass his ass.
I would've much rather seen Rusty win too.  But once it came down to Bush or Jarrett, I'll go with Jarrett.  Even though I can't stand either of them.
