Reverse light wire 2011 Sierra
I have a 2011 Sierra and I'm hooking up an external monitor for an aftermarket backup camera. I am wanting to tap into the reverse light wire to power on my monitor. I plan on tapping into the reverse wire at the trailer plug for the camera. I haven't been able to find out exactly which wire to tap into. Seeing olive, light blue, green, and dark blue listed everywhere and referencing to plug on the far right. I guess I really don't know where the BCM is. I see a box that is positioned vertically under the dash with about 7 different colored plugs in it. I have attached a picture of it. The wire on the trailer harness is labeled Lt Green. Can anyone help me out?
This is the Left I/P Junction block, and it's located between your foot brake and e-brake on the firewall under the black square cover.
The reverse wire is the dark blue wire in the top right pin (pin 8) in the light gray plug in the top right port (X10):
junction_block_left_IP_ACC_IGN_REV_GRND.
  • 3 months later...
Terminal 8 in X10 is the relay trigger for the backup lights relay. This comes from the BCM.
Terminal 5 in X11 is also the same wire.
I am not sure why you are seeing voltage with no backup lights request.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
