Bought a brand new 2014 ext cab LT with the 5.3 back in february. Now that its getting nicer and have had the windows down more often i have noticed a faint squeak every time I accelerate and it goes from V4 mode to V8.
I cant really pin point the location since it only happens when im driving but it sounds like its from the rear. My only guess is it could be the butterfly valve after the muffler opening up when it gets more pressure from the exhuast...
Anyone else noticing this? its just one of those things that is really bugging the crap put of me. other than that the truck is awesome!
Common issue with the adaptive valve. Look for it in the exhaust threads.
http://www.gm-trucks.com/forums/topic/153020-exhaust-adaptive-valve/
A quick way to find out if it is the exhaust valve located behind the rear of the muffler is to place a hose clamp over it in the open position then drive your truck and see if it still makes the noise you are hearing.
Rotate the valve counter clockwise and clamp. This gets rid of turbo whistle sound some are having as well as squeak from v4-v8. I clamped mine Monday and haven't heard a squeak since.
Same thing here. I did it as a test and the noise was removed. I put mine back for now. Curious on the effect on overall engine responsiveness and MPG. Not sure it matters much but mine seems to shift into V8 better without the valve. I know sometimes it seems like it gets stuck and the truck runs like crap.
I did the muffler delete a couple weeks back and was considering taking the valve out also, but I heard it helps a lot with the V4 drone. I will try the clamp open and see how it sounds. It will probably help with the exhaust tone when its at idle too, right now it just sounds like rushing air.
  • 3 weeks later...
I just got my truck back from the shop for this reason. They just replaced my exhaust with a "redesigned" muffler to stop the squeaking.
  • 3 years later...
Did this fix the noise? And has it since came back?
Clamped my valve open a few months ago. No more flappy flap noise
How exactly are y'all clamping the valve? Also does it effect the MPG and exhaust sound?
I had this done to mine. It's not a redesigned muffler -- it's a redesigned Passive Exhaust Valve and it's also located BEFORE the muffler on the new design. Yes it eliminated the squeak.
Yes it makes a different exhaust sound. In V4 mode it sounds like a helicopter is landing on your tailgate.
To all -- search these forums and you will find many threads on this issue. Some of them include great pictures showing the new flapper design.
  • 3 years later...
    Enduro73
    Enduro73
  • Who's Online   1 Member, 0 Anonymous, 1,516 Guests (See full list)
