35" tires 6" Lift MPG
I think anyone with lifts like ours just need to say F-it and tune their truck. Can anyone harp on that? Cause I am on the verge of it. The only problem I am having is that I am only at 9k miles. She is still so young...
I tuned my truck at 10K which is when I put my lift on and everything. Hasn't voided warranty and dealer hasn't even mentioned anything about it.
is that with an economy tune or performance? I am leaning towards a Blackbear auto cal for about $600. It seems that if you really want to get decent gas mileage with these girls you need to get her tuned.
It is with a custom tune by Lew
I get about 14mpg average with the 5.3 and 3.42 gears. It has a 8" Mcgaughys lift and 35x12.5x20 atturo trail blades on 20x12 fuels. Wish it was better and might tune it down the road
Sent from my XT1080 using Tapatalk
7.5" RCX on 35" nitro trail grapplers. No speedo fix, but it always seems about spot on when I do the hand calculations......5.3L.......14-16mpg highway.....10.5-13mpg mixed.....8-10.5mpg stop and go, stop and go. Airaid MIT and 3.42s. What is wrong here? It seems like you guys are just dancing down the road, and I am dragging my sorry arse.
Who did your tune?
Chuck Anders at Houston House of Power(HHP) tuned my truck and literally wouldn't have it any other way. If I pull the tune out I get pissed off because it drives like ish... The transmission tuning was the best part! I tuned mine the second I built it which was when it was at the dealership :-)
Who did your tune?
you see that's the issue I think. I don't have a tune. I'm not scared to jack the truck up, but I am iffy on throwing away my power train warranty. I might wait another 5k-6k miles to put it on, but that is debatable. Will it improve my gas mileage anyone?
I understand the warranty thing. If you cant pay for broken parts dont do it just incase your dealer tries to screw you over.
  • 7 months later...
2014 5.3 with 6inch lift on 35 toyo m/s I'm getting 11 on highway and 9 city.
    RangerRick17
    RangerRick17
  • Who's Online   5 Members, 1 Anonymous, 600 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
