Tire learning mode active?
Last night after work I pulled in the driveway and put the truck in park so I could get out and grab my mail from the mailbox. As soon as I put the truck in park, two loud horn blasts sounded and on the dash display it read "Tire learning mode active" or something like that. Has anyone seen that? It sorta startled me because I wasn't expecting the horn blasts. I'm glad I hadn't just parked in a parking lot as I could have scared someone who might have been walking close by. I'm sure I probably pressed something by mistake? But geeze...I dont have to know about the truck wanting to learn about tires...or maybe pressure. Just go ahead and do it...WITHOUT the horn blasts. When it's done "learning about tires" is it going to call GM via Onstar and let them know they used the worlds shittiest tires on these new trucks? Hopefully so. I'm hoping my truck is spearheading a tire recall effort!
That's the way the manual TPMS relearn procedure used to work. But I was under the impression that GM did away with the manual process around 2011 ...
As stated above that's the way the TPMS system works when in program mode. It sounds like you activated it by accident. The horn honks when the system starts and each time the tire position is relearned so you can do it without looking at the dash.
Now the million dollar question- how did he activate it manually? I'd like to know for when I do my rotations.
Interesting...the new trucks do not have the manual mode...must be something else.
The learning process is initiated through the DIC. If you accidentally hit the buttons in just the right pattern, you could have inadvertently started the process.
The manual process of increasing/decreasing tire pressures for the system to learn where each tire is mounted is no longer supported. Now you must use one of the TPMS sensor tools to activate the sensor so the vehicle can learn where each tire is. (if you don't own the tool, you're best bet is to visit the dealer or a tire/auto care facility)
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 730 Guests (See full list)
