Bluetooth question
Whenever I make a call on my truck's Bluetooth, the people I call always claim I am hard to hear. Is there a way I can increase the outgoing volume?
I get people telling me the same thing. Haven't found a way to control outgoing volume.
Looks like we may be the only ones experiencing this???
In my 2011 it has always been fine. The microphone is in the overhead console near the map lights and passenger airbag indicator. You can try talking more directionally toward that but I never had any complaints.
Thanks, I will look in that area & see if I can see any interference that may block my voice.
My wife says it is because I talk too loud (has not mattered what vehicle I am in). When I talk a little softer, she says she can hear me just fine.
I can try that but my problem is not clarity it is the fact that people say I sound like I am a million miles away. Thanks for the suggestion.
I've had a few GMT-900's, people say I sound better than when on the phone itself. So no volume complaints.
Only been using two phones though. Can you try a different phone and see if you get the same issue?
Perhaps the microphone has an issue? Such as being defective or coming out its holder above the headliner?
I have had the problem on two different phones so I'm pretty sure that is not the problem, I may check the microphone though to see if it is mounted correctly or has something blocking it. Thank you.
GM has a TSB for a new "improved" replacement MIC for "low talkers" or situations "where there could be a lot of background noise".
Ask a friendly GM Tech to look it up for you...? :driving:
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,049 Guests (See full list)
