Has anyone fixed P0300?
I have a flashing check engine light that will come on when I'm on the highway and will stay solid off the highway and then clear. I have no symptons and truck runs fine with this misfire code. Everything I can check or clean I did and even replaced the MAF.
Has anyone had this and what was your fix?
What is the year, make, model, engine? This will help to others to help you. Personally I'd go back over it and make sure everything is nice and tight so there is no leaks from the filter box to the throttle body.
It can be plugs, wires, injectiors, coils.
Intake leaks, fuel pressure issues.....
I've done plugs and wires,tested fuel pressure,nw crank position sensor with a crank relearn,listen to fuel injectors with stethoscope,sprayed carb clean around intake and replaced MAF. It's not a individual cylinder code so intake manifold gasket with new knock sensors since I'm there and maybe a MAP sensor. This is purely best guessing at this point. Again no symptons or running issues just the flashing cel on the highway.
Check the upstream O2's also. When you do a scan for the check engine light you can see the last couple of readings for them. I can't remember if mine just showed a 0 reading while others showed higher or if it was a negative reading.
I scanned mine at O'Reilly's but I would hope that similar scanners would be able to read the flash. Some scanners can read the O2 readings real time also.
Although my truck is the 5.3, this was my issue when I was getting the random misfire code.
After more reading and trouble shooting I replaced the MAF sensor and the 2 rear heated O2 sensors and still no luck. If I throw enough parts at it I might get lucky.
    d.lowrey
    d.lowrey
  • Who's Online   0 Members, 0 Anonymous, 4,540 Guests (See full list)
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
