FS: Mirrors
I have the following GM mirrors forsale:
Passenger Side non-towing mirror from a 2006 Silverado 2500HD. This a power fold mirror with signa and heat. $40 plus shipping cost
Passenger Side non-towing mirror from a 2004 Sierra 2500HD. This is a basic power tilt olny, I forgot if it has the signal in it or not. Will post for sure when I post photos later today. $25 Plus shipping cost.
Also have Passenger and Drivers Power/Signal/Heated non-towing mirrors from a 2012 Silverado 2500HD. $60 plus shipping each or $100 + shipping for both.
All are OEM take offs. Photos posted later today.
Will the NNBS mirrors from the 2500 fit my 1500 Non HD? My drivers side power fold is messed up. It is now vibrating at 80 and will not go back on track.
OK so I got the mirrors out and took some photos.
Couple of things... the 2012s do not have the signal in the glass. Some how I thought they did, but I only seen them on my truck when I test drove it and had them swap on the towing mirrors.
The mirror from the 2004 also does not have the signal in the glass. Also there is some glue on it from a stick on convex mirror that was on it at one time.
Photos are here: http://s768.photobucket.com/user/k2lrv/library/Mirrors%20For%20Sale
Would like these to go soon, so I will entertain reasonable offers.
