2006 Sierra - Service 4WD System
Hey Folks,
Thought I'd run this situation by you all...
2006 Sierra Nevada, 5.3L Automatic.
I've started getting the "Service 4WD System" indicator over the past few months. It first happened in spring. I got the warning and was then unable to move the truck out of "4WD Auto" (my default for "regular" driving). As soon as I shut the truck off and restarted, warning went away and all was well.
It was good for a while and then it happened again, and then again, and now it's happening fairly frequently. Sometimes a "restart" does not clear this up.
Now in the summer, I don't really need the 4WD except for occationally pulling the boat trailer up at a bad launch. But I don't want to leave myself stranded somewhere without the 4WD.
So has anyone else experienced this and found the issue? I realize with all the electronics involved, it may not be a simple answer/fix, but I thought I'd ask.
Thanks in advance.
GMCanuck
Possible encoder motor sensor? Were common on previous years. Check codes for a starting point and diagnose.
Sent from my LGL86C using Tapatalk
Thanks for that. Based on your comments, I've searched around a bit and found some good info on replacing these sensors. Sounds like that may very well be my issue. I'll look to do this repair as soon as possible - hopefully before I may need my 4wd in the next few weeks.
Thanks again.
Thanks again.
you missed the part where he said to have the TCCM scanned ,,,,,DO THAT FIRST before wildly guessing
Thanks Man - I'll look to do that.
Do these codes show up on a typical OBDII scan tool, or is this something special?
No, they do not
    • $5.19 for regular...
    • My office is slowly filling with Blazer parts. Getting ready to do the big bang of repairs. Intake (second time), water pump, radiator, hoses, and I'm going to re-seal the timing cover where someone went hog wild with silicone. Might as well, because I don't think that's done right.   There's a local tow yard that I didn't realize also has quite the inventory of junk vehicles. This is an old school junkyard. No waivers. Cash only, you were never here if anyone asks. Don't piss off the owner, or you'll end up in the back of one of those cars, headed for the shredder. And if you see something, don't snitch. Cars stacked double high, wasps nests, trip hazards and junk everywhere. I found a few little odds/ends for my Blazer. The $20 I spent was worth the experience alone. But I was never there. What yard?   I officially love/hate this truck. It's so out of my wheelhouse, roughest vehicle I've ever owned. Every. single. repair. -is so hard-fought, everything that can go wrong, goes wrong. Currently in a hate phase, and kind of wish I was closer to sending it down the road with a lucky new owner, to be honest. Preparing for the day when I tear into this thing...lots of pre-funk with Ibuprofen.   Rock Auto sent me a bad reman rear wiper motor. It was a bear to install. The tailgate in these things has about eleventy-billion fastners and pieces and things that need to be uninstalled/moved just to access the shoddy rear wiper motor. The casing on mine was cracked clean through, btw. Nice, GM, nice. SO I got this new motor installed, hit the switch, I see it wig-wag (without the arm installed) and think I'm golden. Reassemble everything. With the wiper arm installed I gave it one final test. Time to clean up and take the other half out to dinner, collect a paycheck, right?   Nope. I hear the plastic worm gear stripping as the arm hung up. Just like my broken motor. Weak/old and shredding itself internally. I can assist the arm and the range of motion is normal, and it parks correctly. It just doesn't have the poop to actually sweep the arm with a blade on it. Oh, hell. Turned the key off and shut the shop door behind me. I get to do that over again, too.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
