Root cause would be nice to know; but, a couple of comments and questions. The Active noise cancellation (ANC) system is only operative at certain RPMs. The suggestion of changing gears would change RPM and hence the active noise cancellation (which can, and will, place pressure on your ears). It is possible (but I haven't asked that question) that Active Noise Cancellation behaves differently in 4 cyl. mode. If the problem is related to Active Noise Cancellation, that would possibly explain the differences observed between 4 and 8 cyl. modes. If there is a fault in the wiring of the microphones or in the microphones used in the Active Noise Cancellation, that could very clearly result in the sensation you're experiencing (ie, if Mic A is wired into Mic B's input, then the phase calculations would be wrong.) QUESTION to any of you who've experienced this problem: do you have 4-wheel/AWD? Have any of you installed the "under body shield". Have any of you attempted to record the noise/pressure?
While the roof sheet metal may have been improperly installed at the factory, the sensations and effects noted by those with the problem, in all probability that sheet metal wouldn't have the surface area and freedom of movement to create what you're all saying you are experiencing. That being said, there is one case where it was mentioned ANC had been turned off. That would screw the pooch on some of my speculation. On the other hand, I'd like to know just how the ANC was turned off...there is not a consumer control for that and the only truly effective way is to remove the wiring from the speaker driver used for the ANC function.
Edited by Anon2015
This may help all suffering from the buffeting sound/feel. My truck was with a GM engineer for weeks. I learned today a possible resolution may be replacing the stock shocks and replacing them with NEW/DIFFERENT shocks as well as road force balancing the tires to a particular setting (I am not a car guy and have no idea what that means).
Having said that, I did not drive the vehicle to verify it solved the problem (I no longer own it). Before you have your truck torn apart, ask your service manager to contact a field engineer and see if they know which shocks they are now using in their effort to solve the problem. It sounds promising...hope this helps someone.
Jasondenali15
That sound very intrusting what dealer is you Yukon at?
I know Field service tech’s have different areas would be good to know what tech to contact if info is slow getting back to GM.
Thanks for staying with the cause.
Thanks
Snuke1e
That does add an interesting dimension to it. With low profile tires, road force balancing is important for a smooth ride. Jason were you running on 22", 20" or 18" tires? BTW, changing shocks wouldn't solve the pressure to the ears problem. It does seem however that GM is still pretty much guessing on the problem/solution formula.
I'm just outside of Buffalo, NY. My Denali had 22's but they used all different size rims and different tires for the testing of my vehicle. Perhaps you can find out the engineer is based on location. I do not know his name as I never met him.
A couple of things I learned:
1. They did the roof service bulletin work and it did not solve the problem. They did notice the sheet metal was not attached, but did not cure the pressure.
2. Changed out shocks and road forced balanced tires and they claimed it did. A particular psi range appeared to help the buffeting.
3. I did not drive the truck after they tried the new settings. I cannot verify it actually worked. I tried to hunt the vehicle down to drive it, but it was off the lot.
4. Please keep mind, I am just reporting what I was told. I am not a mechanic. I never had a chance to verify it worked. I am just hopeful you can use this information to prevent your truck from being torn apart for no reason. See if your dealership can contact some engineers and see if they are documenting what is going on in the field with the shocks.
That's all I have...I have emptied my brain on everything I learned. Keep me posted on how it goes out there.
I couldn't read through all this as my a.d.d. kicked in. I was going to sayi have a deep humming sound that sounds and feels like pressure but I noticed the annoying sound comes on when car kicks in to 4 cyl from 8. Is that what we are taking about here?
"road force balancing" what a bunch of hewie ! I've owned ALOT of cars over the last 30+ years. The 2007 Suburban, And 09 Escalade we owned didn't have this sound problem. The Lad had 20, 22, & 24" wheels at different times , NEVER had road force balancing and didn't have this problems.
Our 15 is in the shop right now, been there a week now. BAD DEAL, wife wants her car back. I don't want them to start ripping the head liner out. This shop didn't even know of this problem. Or so they say. REALLY pissed over the whole E85 BS. They say our Yukon is not capable to run this fuel, even though its in all the GM information that it it ??
Was looking on Cars.com for a replacement for this Yukon, has anyone noticed how many 2015 Yukons are forsale? Never have seen this many of a brand new model forsale this soon.
Just figured I'd chime in - ordered my Yukon XL in late August from the factory. It went into production mid September and arrived a week or so ago. I have not experienced any of the issues mentioned in the thread. I'm impressed with build quality, as a previous owner of a Mercedes GL 450. It's among the nicest cars we've owned as a family.
GM customer care responce.
Hello ,
Thank you for reaching out to us. I did read the email that you sent to your local dealership. Did the dealership contact you regarding the email? Are you experiencing an issue with your vehicle?
Regards,
Jennifer T.
GM Customer Care
GM Customer care??????????
Why does GM even support your group?? Total waste of money
I forwarded you the letter I had sent to the dealer with the questions attached. I had asked you GM customer care to find some answers!
You then reply have I heard anything from the dealer and do I have any issues with the Yukon REALLY.
They haven’t even delivered it to the dealer yet so much for being on top of anything.
Spare us your BS and spend the money on R & D rather than a group of story writers.
GM should be ashamed of them selves with the way they are handling this issue.
Good fix fire the R&D and Customer care group. And start over.
I didn’t even get the vehicle yet and I am feed up with just trying to get an honest answer.
Snuke1e
Reply
Report
Edit
Or any answer, yes?
Among the fundamental issues is we are not customers of General Motors. We are customers of the Dealer, who, in turn, is the customer of GM operating under some rather strict constraints. So basically, if you have a problem with your vehicle, GM tosses the problem over the transom to the Dealer to resolve...even if that problem was caused by or is the fault of GM! You'd think that might work but since there is a real serious failure to communicate (equally) to the dealer community, the dealer is handcuffed. The dealer's ability to work through the issues with GM will be directly related to dealer size and volume. If you live in a small market, you're effectively toast. All GM CAC can do is say "sorry" or "apologize" (they really aren't sorry...it's their job to say that) and as quickly as possible dump it off on someone else (like the dealer). Follow up? Nah ... unless you contact CAC again. And again. And again. I think they learned this from the airlines ... if you drag it out long enough the flight will depart...problem solved. CAC doesn't call back. You can send emails. You can call and leave voice mail and never get a response (and if you do it is "sorry") and never get forward progress. If you do actually speak with someone (or with the GM Regional employee with the dealer), what happens at the end of the conversation? "hey...it was that guy again [laughter]". Don't think so? I witnessed and overheard just exactly that. Poor sod just trying to resolve an issue he was promised would be resolved. I guess they didn't tell him how many years that would take, nor that the regional, district and dealer personnel view it as a joke.
Edited by Anon2015
You guys dont know me from a hole in the wall, but I have been waiting for many months to order my wife a Yukon XL (cash saved and ready to buy). We figured it might be a good idea to rent one for a week or so to make sure that it was exactly what she wanted as I am not too keen on spending $60K+ on a paperweight. She has been driving an excursion for 12 years and is (was) excited. At about 30 MPH it made us a bit dizzy with the reverberating noise in the cab constantly searching for that open window that never was. Our newborn would cry for no apparent reason as it seemed similar to not being able to clear your ears when flying in a plane. The suburban had only 3000 miles on it so we figured it might just a lemon and returned it to the rental place for another. We didnt make it 200 yards out from the rental yard to experience the identical sensation in another suburban with only 300 miles on it. One had a sunroof the other did not. We are cancelling the order tomorrow and I am sure we will get the run around from the dealer but I do not trust that they (GM) will go to bat for me when the time arises, should our ordered unit have the same issues. We then rented a new Expedition and that drove like a walmart shopping cart but thats another discussion. At least we could drive a mile without headaches and dizziness. Come on GM, I will order when you promise me a fix on this issue. Its a deal breaker and I feel for the folks that have already purchased. In the meantime, The old Excursion chugs on and I earn that extra nickel a month on my savings account. Then again, I unfortunately doubt GM values my little contribution to the bottom line. Waiting for answers..
You are so smart for renting one FIRST. That's a great idea before throwing this kind of money for a vehicle that was not ready to be released yet. Our 2015 Yukon is still in the shop (2nd week) for the list of things that are not right with it. We were in a 2014 Yukon XL as our loaner car. Took it back, for I wanted to see if another 2015 makes the same noise. IT DOES,( 2014 did not) from 30-50 MPH.
This whole thing has done nothing but cause stress and arguments between my wife and I. She can't hear it, or doesn't want to admit to it ?? She keeps asking when she's getting her car back. I refuse to pay or keep a 65,000.00 vehicle that is so wrong, and makes my head pound in minutes.
Really a bad deal all the way around ! This was to be something nice for my family, and has done nothing but waste time, money, and induce agreements.
Well I reckon it was $350 well spent on the rental. I feel for ya, TOBTEK. It is just a shame that the quality doesn't seem the be there. It is a nice vehicle but I don't think they took the time they needed to get the bugs out. I guess it is a little shocking to me to think that in 2015 in the USA that a roof of a vehicle is not remaining attached to the cross members. Now it sounds like it is more than that as well. I don't have the answers but I think they have focused so hard on technology and the "wow" factor of these and many other vehicles that the basics of structural integrity have been ignored. I drive 30K miles a year on hard dirt roads with lots of washboard. If a rental can't make it to the 3K mile mark without the roof staying attached, I fear what it would look like down the road. I hope they make it right for you (TOBTEK), let me know how it goes. All the Best.
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 482 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
