Some family members arrived yesterday in a rented 2015 SWB Yukon SLT with 18" wheels. I drove it for about 20 miles at highway speeds and also made a stop for gas. There were no noises or vibrations. Honestly I couldn't believe how quiet and soft the ride was. It reminded me of my dad's Cadillacs in the 80s with such a smooth ride and soft suspension. I didn't see any noise cancelling microphones, just one in front of the driver's head which I assume was for bluetooth.
Anyway great vehicle.
OK guys,I just changed the tires with new nexen roadian HP 285/45/22 the ride improved slightly and I disconnected the front mag shocks and what an amazing smooth ride but I noticed when disconnected the speed is limited to 86mph I will put resistor to by bass the limiter,
No buffeting?
No buffeting?
No buffeting, no vibrations, I had no idea if/when it switched from v4 to v8, no problems at all. It had 17000 miles and felt like driving a luxury sedan.
Does anyone know how the roof bows are attached
Two ways. One, tap on the roof with your palm and watch to see if the whole roof resonates. Two, observe the roof while you shut the door. If the whole roof jumps then it is not attached.
Frank
My Yukon was at the dealership for a few days last week for the following:
  • rear axle replacement; rotor to rotor
  • headliner removed and inspected; bows were attached; they applied more adhesive to be on the safe side
  • possible road force balanced the tires some more; [unsure - haven't received paperwork yet]
The above was in addition to another road force balancing session and 2 tire replacements.
Results? It still buffets, peaking at 40mph and 70mph. :tear:
I experienced exactly the same buffeting at the same speeds in the 2015i Suburban that I drove while my Yukon was in the shop. Longer wheel base. Different transmission. Different engine. Larger wheels. Same buffeting.
The truck definitely drives more smoothly, especially at higher speeds. The field engineers were able to record a measurable improvement in vibration aftera ll the above was done - I don't doubt that.
I'm beginning to agree with what Wrench589 and others have been eluding to - this is a more deeply seeded resonance issue with the frame/body and not simply some out-of-spec parts that vibrate. Unfortunately, this is not my area of expertise nor do I have any interest in learning about it.
I just want a quiet truck for my family!
u
That sucks, I'm gonna look for one with 10k on it and see if it doesn't have these issues. Plan b. Consider different vehicle
Frank
Oops I misread, based on my discussions and reading the bows are glued to the roof with a foam material inserted between the roof and bow to take up space.
Frank
Edited by Elripster
I still go back to there being 2 issues, which can be related
Booming / buffeting present in all and can be reduced if there's no
Vibrations, this seems to excite the former issue much more and becomes painful to drive, but not present in all
So if you can find a vibration free one, that's your starting point
Has anyone noticed how much the hood flexes at hwy speeds? The center area of the hood on our 15 XL flexes like a flag blowing in the wind.
Edited by ajs800
Same with ours. If the rest of the truck is doing that...
Frank
Sent from my SM-N910V using Tapatalk
    Enduro73
    Enduro73
  • Who's Online   3 Members, 0 Anonymous, 917 Guests (See full list)
