20sierra14 - I couldn't find any specifics about the mics in the data I have, probably captured in a Service Manual (which is not scheduled to be released until the Spring). Since I don't have access to a mic, see if you can get the following information from yours.
O ring; post 498, page 34, picture 2
-- What is the depth of the O ring (front to back)?
-- Is the O ring hard or soft?
-- Can the O ring be removed?
-- What is the circumference of the O ring outer edge and inner edge? (doesn't look bigger than a dime, use for reference)
-- What is the material of the O ring?
Edited by The Zip
Tobek - "But am reluctant to remove the grills, don't want to break them. So yesterday I placed two pieces of thick masking tape over each of the three Mic's"
Placing tape over the grills will leave an air gap and open air around the microphone...this will create resonance which you do not want (and further you changed the volume around the microphones. The cotton ball method damps the resonance which you do want.
I have two, driven three, and a third on the way. It strikes me for me to escape the problem others are having, I should be entering the lottery. That brings up a question...have any of you, who have this buffeting/pressure problem had the GM Underbody Shield installed? I haven't driven a Yukon without one. I haven't driven a Yukon with the buffeting problem.
What is the GM Underbody Shield? A dealer installed option? What exactly is it.
From the GM website, looks like a shield at the back of the vehicle only.
Very, very, very interesting observation, Anon.
BTW, Anon, sound like you have your own fleet going there! What's up with that?
Edited by Wrench589
Anon2015 comment, "...an air gap and open air around the microphone", is the space I have been referring to as the mic well. Tape without cotton will probably make the pressure or buffeting stronger, "enhanced" could even be a good word here. If you do the tape and cotton method it should probably be as 20sierra14 suggest to at least achieve his results.
If the tires are not the cause of the S/V, the Underbody Shield (UBS), meant to protect from rocks and other debris getting into the engine bay, could also be performing an unexpected double-duty and locking down some components otherwise that could be moving. Offroaders may refer to the UBS as a form of a "skid plate".
If you are experiencing S/V, next time you are in for a service call, talk with the dealer and see what they are willing to do. The dealer may allow you to test drive a UBS or sell you one at a discounted price. Regular price is around 300 bucks dealer installed, Ebay has this OEM part for 54 bucks, free shipping. This is an extremely easy part to install with a basic socket wrench. If I was having this problem, the UBS would have already been in the mail.
Edited by The Zip
The more research I do, the more I am starting to believe the mics are doing there job. But, because of something in the GM design concept (roof, engine, headliner), it appears to be irritating the mics (and us). This is causing customers to address the mic "effect" because no one can isolate the GM "cause".
Based on work I did on the Enhanced Sound thread, I went from 100% Bose mic problem to XM being 100% my problem, thats why I say I "98% believe" the mics are doing their job.
BTW, it is GM's responsibility to figure the cause, customers assuming this responsibility will only be spinning your wheels.
2015 Suburban in shop for the wind tunnel noise.....
I have had 6 different Yukon xl/Suburban since 1997. and loved most of them.
I currently have my 2015 Suburban LTZ in the shop for the Wind tunnel problem.
My family and I get headaches from this when driving for a period of time. It's frustrating. Again it to feels like a single window is down and the pressure is not equalizing.
When is GM going to acknowledge this problem? (or have they?) I have a fleet of GM in my service truck and My 2001 Sierra glides down the road better than this LTZ. I understand it's a truck (my Suburban) but it should just go smoothly down the road and it doesn't.
It has been in the shop since 1/14. They say they are going to refill the gaps in the roof rails with an new epoxy/insulation to see if it fixes the problem.
It seems I'm the guinea pig for this dealer which has never done this before. Now a $70,000 vehicle ( which I am paying for and not using) which is only 21/2 months old is going to be torn apart with the headliner/DVD/ sunroof and etc..
I am sarcastic when I say.."I'm sure I will get it back the same way I dropped it off"
Where and who do you contact at GM?
Has anyone really gotten satisfactory from the roof thing? Is this acceptable for repairs?
What Really is the fix for this?
Is there a buy back or does this fall under the lemon law after a few tries?
Thanks,
Mike P
biginjuns68 - I hate it when a new person becomes a member on this thread because it most cases it means that GM suceeded in putting another family in pain and suffering. But, you became a member at the right time. This train left the station a while ago and at this point, we know more than the dealer. Everything you mentioned with the exception of who to contact at GM has been answered on this thread. At this point in our research, I respectfully recommend you do not allow a wet behind the ears dealer work on your truck in an attempt to mitigate the buffeting. Try the cottonball and tape concept, post your results, then standby
Edited by The Zip
20sierra14 - you have been the only one to try your concept as you described it, at least that we know off per this thread, good job. Answer the questions in post 605 as best and as accurate as you can so that the concept can go to another level. My thought is to improve on what works. I have thirteen ideas on moving to the right of what you did, each one can work singularly or in combination. So when you provide the info coupled with me getting some grilles, we'll press on. When I am done, I will send you the grilles for a test drive. Another question previously unanswered, is the mic well in a finite, enclosed space?
Again, we are only mitigating an effect to a cause, our goal should not be to figure this out (too complicated). We just didn't give GM 70K without any accountability; we don't want to let them off the hook
Edited by The Zip
Sorry for late response.. If you ever need some info, quote me - I'll get an email when you do :)
Depth - I don't have anything to measure that small, but maybe 1/8th of a inch..?
Soft
Cannot be removed - Glued (most likely) to the plastic behind it
About 3/4 of an in wide
Some squishy, sound-deadening foam.. Proper name? No clue.
No, the openings are NOT enclosed... My fingers can feel all around the back of the headliner.. In other words, I think the mic is mounted the metal roof and then headliner was just placed on top. The mic doesn't seem to be concealed off in its own space.
Edit: I just ran out to check.. the mics are NOT concealed to their own enclosed space.
Edited by 20Sierra14
Ok - got it. Set back with your response. Without the mic being in a well, your concept will degrade over time, another reason to press-on. Occasionally repack the cotton to mitigate this. Not a big issue at this point, as my ideas don't involve cotton. Your photo surely looks like the depth is deeper, do this. Take a standard stick pin and place it in the opening. When it stops, provide me with the percentage of the pin left exposed.
The grille you provided in the photo 1 is the one for bluetooth. Pop off the grille again and see if the mic is similar to the others. If so, I will be able to get measurements.
Edited by The Zip
    Greg3160
    Greg3160
  • Who's Online   2 Members, 0 Anonymous, 476 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
