New 2014 GMC Sierra Owner in SouthEast Michigan
Hey all!
Just picked up my first truck, a 2014 GMC Sierra SLT All-Terrain CCRB 4x4 in Switchblade Silver Metallic. It's got the 5.3L and 3.42 gears.
I bought it used, certified pre-owned with 17k miles on it and it's in great condition. It's covered under the rest of the factory warranties(bumper to bumper and powertrain), plus an additional 12mo/12k on the bumper to bumper. There was one small issue with it that I didn't notice until I picked it up. It's supposed to have a power sliding rear window, but the previous owner must have smashed out the rear window due to something in the bed, sliding forward and hitting it, and had it replaced with a standard window. Which it turns out is better for visibility anyway.
I also noticed that the transmission or drivetrain whines at low speeds and on startup. The engine or something sounds loud almost like a ticking. The dealer says it's common for these trucks to sound that way. Anyone else have these noises?
Overall I'm very happy with the truck. It's a lot nicer than my mom's '07 Silverado. I've been averaging about 17mpg in the city(15ish in stop and go traffic), 18.5-19 combined, and 22-23 highway, these are all DIC numbers. When I hand calc'd the overall tank avg with the DIC avg, the number was within 0.2 of a gallon.
Once my rally car is finished, I'll be towing it 1-3 times per month.
Any suggestions, tips, tricks for maintenance, driving, towing or general stuff that I should know about?
welcome aboard
Post some pics of the truck and rally car. Where do you race?
welcome aboard
Thanks!
I'll get some pictures up once I log into my computer, just been using the phone for internets lately.
The car is currently being torn down for a new engine and suspension, but I'll get some pictures up of it as well.
Welcome!
Thanks!
Welcome!
The ticking sound is normal for direct injection engines. I have three vehicles with direct injection and they all make similar ticking sounds though not all at the same volume.
Here's another shot of the truck at work.
Here's a couple pics of my rallycross car:
My BedRug liner was waiting for me when I got back from camping and my Fold-A-Cover G4 Elite should be waiting at home after work.
If I'm feeling up to it, I'll get the stuff installed tonight. It's supposed to rain until Thursday, so maybe it'll get installed then.
My AVS vent visors are on the way.
Still deciding whether to get the WT no-drill mud gaurds or not.
I'm also considering getting some tint on the front windows, not as dark as the back windows due to our tint laws, trying not to make it so obvious.
Loving the truck so far... I've put nearly 1500 miles on it in the 3 weeks I've owned it.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,252 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
