Front Locking Differential
I have a 99 Silverado Z71 with a stock rear locking diff (G80) is it possible to purchase this same one for the front end?  I dont think I want to spend $600 on the Elocker
-KMT15
Why, If you could add an eaton E-Locker, what wrong with the mechanical version?
-KMT15
I don't mean you couldn't put it in but I don't think the truck will go where you want to on slick surfaces.  I believe this is why they aren't offered from thhe factory.
Not 100% sure, but i think 4WP's is offering the new Eaton E-Locker.
He just means that a locker up front wouldnt handle too well since you need some slip to turn corners.
Any manually activated locker would work well tho.
My buddy has lockers front and back on his jeep, but he doesnt mind it much and doesnt drive it alot either.
can you explain that?  I really only want it for off roading
-KMT15
In that case, go to it.  Maybe.  I do think that negotiating hills sideways might be a problem and is one reason they aren't that popular.  It's worth a try anyway....let us know how it goes.
You can't put the G80 int the front.  Two completly different diffs.  Like comparing apples and bricks.  Also, as of now nobody makes anything to lock the front axle on an IFS Chevy.
Rick
Rick
:cool:  :rolleyes:
:P
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
