Ran my supercharged2014 Sierra Denali 6.2l at the 1/8 track
Boombastic
Just got the Magnusen tvs 1900 installed. Best stock run was 9.44 seconds with a 60 ft of 2.10. My best with the SC was 8.6secs@ 78 mph with a 60 ft of 1.83. Not to shabby?.
I've got a good vid of the truck a a pic off the timelslip. But haveing a hard time posting here for my ipad
Yep. Got a couple of vids a few pics of timeslips. Can't post them from my ipad , don't know why.
Edited to fix triple post
No, didn't know him. But I chatted with him later and he was very suprised. I Also did the same thing to a fella with a 2011 stock camaro SS . The camaro ran 9.8 against my 9.6.
  • 1 month later...
This was 1/8 mile run right? I might have missed this but is yours 4wd ? I ask this due to my 2wd 2012 Silverado with 6.2 is running low 9's high 8's 1/8 and I have no SC, but I do have other mods. Mine is the LT CC version which is somewhat lighter.
My #'s are recorded from a performance meter I own and based off 10 different runs which all seemed to stay within the same ranges.
what's with this 1/8 stuff? Let's talk 1/4 mile times!
never had the chance to run 1/4 mile with the SC. BUT I did run the truck with the SC and Headers in the 1/8 and shaved off another 3 tenths and got 8.38 seconds. I then went and ran the trick in the 1/4 and got 13.1 in 4wd. I would gusess that if I did get to run in the 1/4 with JUST the SC I would have run AT least a 13.6 secs.
Those are much better #'s !! I wont be adding a Sc but will add headers and the under drives pulley setup for a few extra ponies. I had 3 back to back 1/4 mile run's with my current mods and hit the mid to upper 13 mark ( mines 2WD). My biggest issue is getting wheel traction.
Boombastic I would bet your spinning even in 4WD ?
  • 1 year later...
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 1,000 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
