Programming Keyless Entry
It is my understanding that programming for key fobs must be done at the dealership. I've always driven Fords and I always buy a stick on keyless entry keypad for them. I hate to carry my keys with me if I'm out fishing or riding the atv as I don't want them to fall out of my pocket out on the trail somewhere.
I know this is a Ford product, but does anyone think it could be programmed to a new Chevy? It operates on the same basic principle as a key fob, it just has a code to enter instead of a single unlock button. This is about the only thing I miss about my Ford.
I seem to remember a few years back there were some keyless entry systems like this on Cadillacs, but that was before they went to passive entry systems. But I could be remembering a Lincoln I had for a short time...
Doubt it'll work unfortunately. Those keypads were largely a Ford thing in the past and now are pretty much exclusively a Ford thing. You could have a cheap metal key cut and use this to lock/unlock doors to get to the real keychain.
That's a good question. I have a fleet of trucks, and I put these on my fords, due to the fact they always lock their damn keys in the truck. I will look and see if I have extra and try it. Couldn't hurt. Nothing to program. I do miss this on my f150 as well.
I had to order another one for a new truck. I'm going to try and see if it works. If not, my SVC advisor is a buddy of mine, I will ask him and see if he knows. Keep you posted.
I seriously doubt this will even remotely work. It would require this pad to operate on the same frequency as the GM fob. Then would require the GM BCM to be programmed to accept this pad and that is if the GM BCM can have more than 2 things married to it.
A lot of variables there for sure.
I bet it can be done. Just going to have to find a good dealership tech that's willing to try.
How? The keypad thing is exclusive to Ford. No one else does it. Ford vehicles can likely be configured to work with the keypad. A GM one? Not so much.
I always put them on my fleet, I'm going to have it anyways. So why not try and see? Worse case it doesnt ..... I'm not out anything. If it does.. One more add on that I missed about my F150..
    Sothpaw27
    Sothpaw27
  • Who's Online   5 Members, 0 Anonymous, 688 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
