in process of taking tires of to see if that's the problem noticed rear pass wheel bearing is sloppy pulls in and out other side don't would that cause the death wobble? and how hard's it to change rear bearing? never done rear only front with hubs.
Rear axle bearings are not anywhere near the same design as front wheel bearing designs. In and out movement is normal on rear axles, and is nothing to do with bearings. On the light truck rear axles there is a "c" clip that holds the axles in, and axles will move in and out normally. No connection to front end.
but one side goes in and out bad compared to the other side maybe 1/16 of inch or less it has way more play then other side and I noticed today both tires on back must been on front and the outsides bald and inside has tread still pretty good tread. and when I let jack down the tires tilt toward outside there not straight its very noticeable is that a problem? Im taking it in to shop tomorrow but I never trusted them cause my mother in law took her jeep cause it had death wobble at 60 when u brake only at above 60 not 58 it would be fine they replaced 850 worth of parts and still did it come to find out belts were blown in both front tire form it sitting for years not moving .,I just don't want to spend a lot of money and not have it fixed and I got all new skyjacker shocks coming next week cause I ripped one rear shock out the day I got it taking kids in field and doing donuts cause they wanted to. and when I had one side jacked up yeaterday I had bad play in front with tire rod and what ever its connected to but when I jacked it higher when both were up it had very little play.
Just remembered having an '85 or so 6.2 diesel K30 dump body here with that same issue. If you hit a bump at around 20-30 mph, the wheel would go into a violent side-to-side wobble that wouldn't go away unless you nearly stopped. That started after we replaced that 5' long tie rod - all correct parts, installed to the same length as what was removed.
I added 10 psi to both fronts, and the problem mysteriously went away! That was a strange one ....
Truck was a rotted out POS, so throwing money at it was not an option. Probably in the junkyard now - this was 2-3 years back. I don't miss working on that turd, I can tell ya that!
Sometimes people think too much about stuff they don't really understand and end up trying to use the knowledge they have against an issue it does not apply to, and get an answer that sounds solid to them. But it is not.
Your truck has a solid rear axle. There is no provision for any camber adjustment, and caster does not apply. Any angle you see in the rear wheel after lowering from a jacked up position is an illusion. Roll the truck forward one wheel rotation and see if you still see it. At most you may be seeing that the truck is not on level ground, and after letting jack down the truck has leaned over to one side while being dropped. The axle end play is completely 100% normal. All vehicles with that type of rear axle have end play. It does not create any issue, does not create any vibration, and will not create a noise.
If you have an issue with a defective tire, you would be getting a vibration or steering wheel wobble from a dead stop as you pull away.
Tire wear on outside edge, both sides is usually caused by excessive toe in. Reason I say that and not excessive camber is that having both sides with excessive camber is not common, where as excessive toe-in is applied to both front tires in order to keep truck going straight.
The reason you do not get the play in the tie rod end with both wheels off the ground is that it is easier for the other tire to move than it is for the play in the tie rod end to move. Check front end parts on one side at a time with other side on ground until you get enough experience to understand what is happening.
Just because the shop looks at it does not mean they have to fix it. Get the estimate, go home, think about it, then decide about what to do. If the shop wants to charge for the estimate, ask if that will be credited back if you get the work done later.
  • 5 years later...
We have a 2001 Chevy 1500. It has a major death wobble. We replaced the tie rods, pitman & idler arms,  steering stabilizer,  u- joints and it still does it. A mechanic is telling us it's the abs brake module & pump, others are saying steering box. Thoughts? We've had the truck 7 yrs and have had good luck with it until now. We've already dumped over $3k into fixing things and it still about throws you into the barrier shaking so bad.
    • I see some red flags.   - No mention in the Carfax if the oil pump belt was changed.  LM2s had a 150,000mi service interval, and its got 164,245mi on it.   - If something happens to the transmission valve body, the special coverage is expired by mileage.  That will likely be an out of pocket expense, with zero or near zero GM participation if something happened even though its in by time.   - 2020 LM2s seem to need timing chains after 80,000mi at some point.  They fixed this end of 2020/starting 2021 model year engines.     - Long oil change intervals.  7,000-8,000mi on average, probably close to 0% or perhaps to or beyond 0% on the OLM.  Lots of them not at the dealer which makes me wonder how much of the oil ran through that truck was the proper Dexos D rated 0w20 oil and not just gas engine 0w20, which is not the same at all.     - Long fuel filter changes, again likely taking the fuel filter life to 0% or more.  First one went 28,603, second was done 43,094 miles later at 71,697, from there another 46,452mi to 118,149mi, and then the most recent one 37,026mi later at 155,175mi.  So counting its original fuel filter, its had only 4 fuel filters on it.  No bueno IMO.     Good news?    - It has had only two warranty trips to the dealer.  The first free service (end of December 2020 on the Carfax), and the transmission reprogram recall (end of August 2025 on the Carfax).     - Truck did a LOT of moving, so that might explain the lack of emissions related repairs like bad NOX sensors, bad exhaust temp sensors, bad glow plugs, etc.     The "emissions system checked" could just be how something was flagged for Carfax.  GM dealers have to do SAVI reports for warranty repair orders so they scan the truck.  So its possible that is there for that?
    • Thank you, @Z45!   NOTE - No all repair shop/Dealers reports to Carfax   That is my main concern.  The CARFAX looks way too clean for a 6 year old anything with 164,245 miles.  Even something known for reliability (like many Toyotas) typically has a lot more replaced, like a Nav screen, interior trim, shock/strut, or brake pads.  And surely the last set of tires (installed at ~58k miles) would be bald unless those were all highway miles.   I'm tempted to pay a local dealer to look up the VIN, but am not sure if that will be worthwhile.  Last time I did this, it was 100% useless, and I felt scammed - they noted the bumper was replaced years ago and that's it.  A 5-year old could spot the accident damage, even though nothing was on the CARFAX.   After giving the dealer a call, the truck may have a hard shift, but they have to verify with their mechanic if that's even a concern.  And I've test driven about a dozen of these now, many near Chicago, and half the trucks shift hard/odd at all throttle positions.  The ones with aftermarket lifts/larger tires shift terrible, and 3 stock trucks shifted so violently I thought the transmission valve body was going out.   At this point I'm conflicted, as I need a vehicle, and am coming up short locally.  Northern trucks in this price range tend to have either multiple owners, a lot of mods (lifts/oversized tires without re-gearing), and are generally in rougher shape.   If this truck showed up in your neighborhood for $27k and you had to purchase it sight-unseen, with the possibility of needing a 10L80 rebuild, torque converter, or rear end - would you do it?  I'm convinced most of the 10L80 trucks I test drove are broken, they can't all shift so bad, with massive flares/slipping/lurching and mis-matched downshifts like a teen driver learning stick.
    • From the spy shots, the front end does look like it's borrowing some styling cues from the Canyon. I'm more interested in the powertrain news than the screens though. If the 3.0 diesel survives into the next generation, that alone will keep a lot of current owners interested.
    • What is this tuner you mentioned that can shut the system off?
    • I had it tested at the hardware store, and it showed no chip. He went out to started the truck today and it wouldnt fire. He waited an hour then tried again, and it started 3 times. In a row. My 2000 cavalier did not have a chip key, but still had a security system.  🤷‍♀️
