Help with rims and tires for lifted/leveled 2014 silverado
I am about to install the RC 3.5" lift/leveling kit on my 2014 Silverado LT Z71, and I'm looking to buy aftermarket rims and tires. I went and priced a few setups and was blown away by the estimates. I'd rather just do my own research and pick the brains of fellow lifters on here to find out what I need and save probably $500 in the process. I'm looking for an offset rim that will put the tire outside of the truck about 1-1.5", I prefer the look of a 17-18" rim and will be purchasing semi-aggressive all-terrain tires. Most importantly, like most I want the largest tire/rim combo I can get without rubbing the fenders/wells. Any suggestions would be much appreciated.
I responded to a similar question yesterday and as I mentioned there, I sell large commercial truck tires for a living and would love to help your out with tires and wheels for your rig but we stick to the big stuff. I'm not a "lifter" so have no advice there other than to do that first so you can then move on to the tire and wheel size and determine what will work. Whenever I have a customer that wants to go with larger or different than stock wheels on their rig, my best advise is find a tire shop that also sells wheels and bring your truck to them so they can first advise you on what tire size, wheel, and offset will work, offsets can get very tricky. The only way to know for sure is to mount up the tire size of your choice on the wheels of your choice and test them on your truck, otherwise you are guessing unless you run accross someone that put a certain size on a truck identical to yours and can verify with out a doubt that it worked. In particular you want to mount and install the steer tires to be sure they do not touch the frame or fenderwells when turning to the max either way. New tires and wheels are an expensive proposition and any shop (that cares) wanting to sell you both should be willing to take the time to help you out, do some testing, go through the work and properly determine what's going to work best, if they aren't willing to do this, move on to the next shop. National chains (with a lounge, TV's, kids play area, and free coffee while you wait) are probably going to be less likely to help as they just want to sell you tires and get you out the door and on your way, I'd be looking for a good locally owned "average Joe gearhead" shop (you'll know it when you walk in) that can relate to you instead.
Go with an 18" x 10" wheel with a -12 offset and a 33x12.5r18 tire.
It will get you the look you want.
Maybe I'm wrong and 14's can handle that, but I would imaging that would involve a fair amount of trimming.
As far as wheels and tires go, what kind of prices do you consider high for a 17 / 18" combo? There's some really cheap wheels and tires out there to go with that cheap lift.
I don't see why it wouldn't fit, should be fine especially if the lower air dam is removed.
Like I said, I could be wrong and maybe the 14's fenders are that much larger, but there's no way it would work on the previous gen.
From the guy I spoke with at the rim shop he mentioned 305's would be about the max width I'd be able to run without trimming. I picked out some rims that priced out at about $225/rim (didn't really care for them, I know there's cheaper out there that I'd rather have), he added nitto grapplers, lugs, resetting pressure gauge, mounting for $2200.
$2200 is pretty good. You may get a little lower. Much cheaper and you're talking steelies and junk tires. Or you could go used. I paid more than that just for tires. As far as size, you can get away with a 33 x 12.50-ish sized tire. Wheels should be in the 9" wide range with 0 to +18 offset range. That would rub on a truck like mine but your 14 May pull it off.
Go to the little tire shop, not to those big fancy ones. Pay cash and they even make it cheaper
Where do you go in H-Town? I've been looking at all the GM replicas on Houston Craigslist. Lots of good prices but those tire brands are scary.
Truck1
RC 2.5 Kit, stock 20" All Terrain wheels, 34" Toyo Open Country MT (Toyo specs 34.5x11)
Slight rub nothing worth trimming.
There is a thread here somewhere with a list of tires, rims and lifts and whether or not anything rubs there are a ton of responses in there and you will probably find your answer there :)
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 309 Guests (See full list)
