Whelen Reverse Lights
I'm a landscaper and plow guy. Usually I put reverse lights on the backrack and remove the tailgate for optimal light in the winter, but with the backup camera, I didn't want to pull the tailgate on the new truck. I spoke with a good friend of mine who is a Whelen dealer, and he came up with a great plan. He plasma cut the bumper, and installed two Whelen 500 series linear led lights. Wow, these really do the trick. Looks great and performs great. I highly recommend doing this if your a plower, what a great investment. I'll add daytime pics tomorrow, but at least you can see the night pics for now. aeabbf25b267e4971ec5325391de6b94.jpgec2453ffad72667ff6f94bce86f71bd7.jpgcfbda5f26a33878bda43cc52f9f3ec1f.jpgfad9d981269289e05cb7723a7639740e.jpg
They look sharp. In the past I've mounted to the bumper or hitch and the lights would always get knocked out of position. So I went with back rack mount on my new truck, also a 2015 2500HD (gasser though). I really do like the way yours look though. Seriously making me reconsider.....
Thanks man. It wasn't my idea, it was my local Whelen dealer that came up with it, so I don't want to take the credit, but man... They are bright and look factory. He's also installing a Whelen century 23" mini bar as well as two Whelen hideaway modules on the rear. I'm pretty excited about it... More pictures to follow.
I've got the 16" Century, and just installed clear LED flashers in reverse lenses today. So far very happy with Whelen products.
Good luck with the truck and weather this year. I know I'm hoping to recoup some of the mass funds I've expended the last few months.
Do they work well with the backup camera? I want to assume it would be so bright for the camera that you would see more white than anything. Of course I don't depend on the camera when backing up, but it would be nice to have a little more like for backing up at night and be able to see better out of the camera. Factory reverse lights are good, but the light to help the camera could be better.
I'm a sub that gets paid hourly. I need snow. Outside of "normal 9-5 hours" since I work a regular full time job. Or enough snow to shut down my office, which is rare, but did happen a couple times last year.
No, I'm not. I've browsed it lots of times, but I never joined for some reason. Might have to change that.
Sent from my LG-D850 using Tapatalk
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 525 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
