2014 Silverado
Could be a number of things.
Do you have climate control?
When you say a/c not working I assume this means no cold air, fan works fine? Air is ~room temp? Does it work heat wise if you turn up the thermostat(s)?
Could be a blend door problem, could be a/c clutch issue, low refrigerant, could be a bad pressure switch, blown fuse, or it could be like the problem the ~2010-2012 camaros had where the a/c compressor shaft breaks off. :lol: lord I hope we don't have THAT problem.
Blows hot I was thinking the blend door was stuck but the a/c clutch is not engaging. I have the climate control. Its kinda sad that a 45000 dollar truck loses the a/c after 15k miles
I have a 2014 silverado that just turned a year old. Today on my way home from work the a/c was not working. I am bringing it in tomorrow. Has anybody else had this problem.
We regret to hear that your A/C stopped working in your Silverado. I see that you'll be taking it into the dealership tomorrow. Please keep us posted after your visit! If you should need any additional help, please let us know!
Andraya
GM Customer Care
  • 3 weeks later...
what was your resolution- mine went in 3 times for it not working, turns out there was a hose leak that when idling wouldn't spray coolant out but uner acceleration it would. they replaced ac compressor twice before figuring that out.
Stuff happens. Which is why you have a warranty. Take it in and let the dealer fix it..
Yes, I had this problem. I took it into the dealer, and they checked it, and said it had too much refrigerant oil in the system. They drained it out to the correct amount and it has been fine since.
Hope this helps.
Sorry i forgot to reply. It had a crack in the discharge line coming out of the compressor where it 90s. They replaced the line and i have had no problems since!!! Maybe i just had a bad line and it wont happen again.
mine was basically the same
  • 3 months later...
    Patrick Fergy
    Patrick Fergy
  • Who's Online   2 Members, 0 Anonymous, 1,046 Guests (See full list)
