2014 Sierra RCSB Subwoofer help!
I have a 14 Sierra SLE regular cab. And I want to upgrade my sound system. The stock non bose door speakers are actually not bad. Some songs play really well with these little speakers. A friend of mine is going to sell me a pair of brand new 10" kicker CVR subs. now I dont know much about powering up these systems, but do they even fit? Can I power those subs with the stock radio without it sounding crappy. Can someone give me a run through on everything else I need after the subs?
The non-bose door speakers don't have that great of sound reproduction... They are pretty basic mids with felt-like construction. I replaced mine and get considerably better sound definition... Now I just wish I could access the tweeters in the dash and update those.
  • 3 weeks later...
Yea I hav a reg cab also and I'm looking to upgrade. Any info out there?
It's a shame that us reg cab owners can't get the same as a 4 door truck.
yeah man I feel you. Funny thing is I could of gotten a crew cab. But not what I visioned
  • 8 months later...
Any new info on this thread? I'm looking to upgrade my stereo next and was looking for some advice to what fits. Who's done what?
