offroad lights
Rat_city
alright so i just installed a n-fab light bar for my 14 silverado (it was a pain to install) and i have 4 kc lights, 2 driving lights and 2 spot beams. i need help wiring these lights. how i want these to work is the driving lights only come on with the high beams but still have a switch. so that was they arent permanent on if i have the highs on. and the spot beams i want to be controlled only by the switch so theyll come on whenever i flick the switch and thats it. any help?
Easy to do, just run from the high beam, to the switch, to the relay. And for the other all you need is to hook the switch to something hot, then the switch, then relay.
awesome! thanks guys. i dont have any experiance with electricals. like if its not plug and play im clueless haha so i hope i can figure this out.
