01 Sierra 1500 brake issue. please help
Ok.. here is the situation
Have a 2001 sierra 1500 4.8 v8 ext cab with traction control. recently the brake line rusted trough and I have no brake.
My friend offer to do the work for me however after changing the 2 front line we are not getting anything on the rear brake.
Rear brake lline have been tested with compress air and is ok. Master cycl have fluid coming out to the abs pump. From the abs pump 2 line goes to the front and they are working but the back port have no fluid. My friend thinks the abs pump is clog and needed a new pump assembly.
The pump assembly have been disconnected long ago because it run all the time, which mean the control module is gone on that thing. However I also heard that one must have a working pump in order to get the thing to bleed along with using a compression pump.
So does that mean if my abs pump control is messed up.. I am doom? Also here is the kicker I can't get a reasonable abs pump assembly with traction control locally in Toronto Area, Could i plug in a non traction control pump? If not what could I do to get it bleeded correctlly? and could I do it without it powered on?
I have also read that someone with other truck manage to bypass the whole abs and go straight to the master cycl.. but don't this require the truck to have a proportioning valve? I read that on this truck, it is part of the abs pump and also how to split from the master 2 lines to the 2 front and 1 rear brake line?
Any help will be great
Take it in , don't mess with your brakes for public safety sake , the Internet is NOT the place for this concern ,
No abs means normal everyday brakes , you have a problem or someone doesn't know how to bleed brakes and ya need a licenced tech
he is a licensed tech.. it is at his shop on the hoist. Even a licensed tech don't work on the same vehicles all the time, so sometimes weird issue comes with with different card. I am just trying to get a second opinion as there are other experts on this truck.
There are many discussion on this topic all over the internet that bleeding this truck is a pain in the butt.
Also did you not notice that I said I can't get an abs pump with traction control? So how am I suppose to get it back on the road? I needed to know if I could just use one without traction control just to get the brakes bleeded and working and then disable the system?
you call a GD parts guy about the different ABS crap , not the Internet , it is about programming the modual as well , you're asking a question that is impossible to answer unless your a parts guy with your VIN in front of him ,
Stop posting more than 1 thread about your concern , it's not nessassary ,
    • Because single shot injectors are ancient and multi hole injectors provide smoother running engines and sharper throttle response due to the fuel being atomized better..the best lead I have is a 24lb blue top injector almost everything matches up but the injector will put out about 26lb/hr which is just outside the gm threshold.figured id ask here to see if there was an absolute answer
    • Why is my question?   Any change in injectors requires a tune. Unless you are going back with the OEM part number or a newer part number of that same injector.   Any size difference or type difference like the EV6 style injectors all have different injector data for them. And there is no EV6 injector that matches the factory 25 lb/hr size that your truck comes with. I've been messing with these trucks and tuning them for a long time and what you trying to do doesn't exactly make sense to me.
    • My 6.6 gas lt8 had lifter noise with 28000 miles bought new 2026 and while driven to dealer it threw #1 rod bearing “HD my ass” good luck with yours i hope it don’t turn a rod bearing!
    • When a condition becomes a business model.    https://www.gm-trucks.com/gm-truck-suv-incentives-pricing-2026/   Zane posted this in "Latest Articles".    The honest bottom line   Truck buyers have spent three years assuming this is a temporary condition that will break once inventories normalize. GM just presented it to investors as a durable strategy, on a chart, as evidence of good management.   Inventory did normalize. GM is at 511,000 units and squarely inside its own 50 to 60 day target. The discounts still did not come back, because the low incentive number is the goal rather than a symptom of shortage.   Plan your purchase around that reality instead of waiting for it to change. Follow our ongoing GM News coverage for pricing and incentive changes as the next-generation trucks land.
    • Thought it was raining this morning when we woke. Nope. Dew point was over 80 F and humidity 98%. Zero visibility distance. Everything was 'sweating'. I've seen rain come out of clouds but never out of Pepper or the tree trunks.    Wicked storms just missed us sliding off to the east but by blocks. Heat index about 110 F with air temp in the 90's.    This is  our third wave this month of multiple days of this type of weather. And yet the grass is going dormant and the ground is cracking this side of the street and water up the the hood opposite. Just weird stuff going on.
