Need to dim down LED rear lamps
I updated my rear tail lamps with an Ebay sourced LED version only to be told by those that follow me they are extremely bright at night and if it weren't for the third brake lamp they couldn't tell if I was riding the brakes. Does anyone know by way of using a resistor if I can turn down the voltage from 12 VDC to 9 VDC or to reduce the amperage by 1/4 watt? Also, if the resistor needs to be wired in parallel to the lamp or in-line (series) with the 12+ lead?
Thanks
Stephen
Regular LEDs are not dimmable. They operate at a range of voltage at the same brightness. If the voltage drops below that range, they go off.
LEDs are brighter. That's the point. I love mine. Converted both my trucks. Don't worry about it.
Switching back to your OEMs is the easiest/simplest solution, if you're really concerned about the drivers behind you.
use a pot to set the brightness, and yes you can dim an led
yes, just read up on them and that should do the trick. Thanks!
Without know the current draw or power rating (wattage) of the LED lights, this is mostly an educated guess, but I am pretty sure this should be about right.
I would try something in the 220 to 470 ohm, 5 watt range. Radio Shack might be a source. Don't buy the small little 1/4 or 1/5 watt resistors. They will probably overheat and burn up, but 5W shold be safe. You don't have to be concerned with buying a resistor that has a higher wattage rating than you need, but a lower wattage will overheat and fail.
    ballencd
    ballencd
  • Who's Online   4 Members, 1 Anonymous, 595 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
