Anzo headlight U Bar lights with HID projector help?
So I have an 08 Sierra denali, with aftermarket hid, I purchased a pair of black U bar anzo projector lights and ordered the correct hid bulbs. Has anyone installed these. I ask because the low beam projector is somewhat sealed and not sure if I just cut the rubber cover to put the hid bulb in or if theres a better way? Thanks a lot for any help
  • 4 weeks later...
So new question, installed the lights and they look phenomenal! But the HID bulbs cause the cutoff to be way too low to be useable at night, they are adjusted as high as possible. Anyone with experience with this. I hate to take out the hid's and just run regular bulbs. Are Led bulbs an option, or maybe same issue?
I am in the same boat of lackluster light output due to projector adjustment. I just installed these and have them as hi as I can go the adjusters just spin now.... guess I have to put a call into anzo.
I am also interested in putting HiDS in. What company did you go with and what size are they now for the anzos?
Also were you able to get the installation instructions pdf to open?
Well from what I understand the hids are causing the problem i guess. I was hoping if I put the halogen bulbs back in that they would work better. I didn't try to open the pdf.
Ok so I took the hids out and used regular bulbs and its still way to low to drive safely at night. Sent them a message but no response yet, not sure what to do from here. The lights look great but unusable. Anyone know of an economical place to mail the lights to and get good hid projectors installed into these Ubar lights?
  • 1 month later...
Thanks for the reply! Currently, my distributor got me a new set, they get installed weds. So hopefully these will do the trick. I am going to put the hid's back in too, when talking to the anzo customer service rep, he said where it says non hid compatible, its mostly just a legal issue. So thats the route I'm doing now, if it doesn't work, well I don't know...
How do they look?
Could you open up the anzo's and put in some aftermarket projectors from TRS if the swap doesnt fix it?
From what I understand, if the headlights did not come from the factory they are not legal. But, if you swap to another factory standard projector or similar then most inspections wont notice or care typically.
I am planning to put together a long post about my projector retrofit soon with lots of pictures.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
