2006 2500HD brake pads
I have found terrible brakes... The EBC's I had on my pickup made so much of a mess I have to call them terrible. There's good and bad aftermarket. My Delco Ceramics can still make ABS kick in... and that's the most any brakes can do really.
All in all I'm happy with the Delco's, they last a long time and run clean.
I can't believe the price of their pads. I think the green stuff pads for the Cruze were $118 last time I checked. Crazy!
Firm up the what !???? Holy shit lmao !!!!!!!!!!! You guys kill me , love this site soooooo much hahahahahahaaa !!!!!!
I fail to see the humor... did I use an incorrect spelling? Or are you implying that my technical knowledge is faulty?
i just cant see braided lines firming up anything thats all
The idea is that a braided line will be stiffer and will bulge less than a traditional rubber line. When brake pressure is applied, the rubber lines at the wheels expand from the pressure and that expansion reduces brake power and pedal feel. The braided lines just help keep the line from expanding and thus losing brake power.
i know what you mean
Oem pads on my dually lasted 157k.. Replaced with the same,
Front pads 275.00 Oem at mechanics price
Rear pads 240.00 Oem at mechanics price
Aftermarket are in 90.00 dollar range. for my truck
Cannot afford to fix it right then buy crap!!!!!!
IMO Scooby
That sounds like a price for pads and rotors... I guess the HD pads are more expensive. The aftermarket pads I had were far more expensive then the Delcos.
Those pads only.... for my 08 dually HD..
Scooby,, Ontario /canada
Do not even think about my rotors at 650 a pop !!
Stick with OEM Pads.
They last and have zero brake dust.
Are there any aftermarket pads out there that are comparable?
I need new front rotors.....but will probably use OEM pads unless there is a comparable aftermarket option.
I just need new solid rotors. Nothing fancy...and clean pads.
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 528 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
