Bedslide question
Horacio
So I ordred and received a Bedslide 1500 Pro CG for my Denali. I unboxed it and holy $hit is this thing heavy! Does anyone have the 1000 SE and is it heavy as well? The mfg website only gives weight ranges. Putting this thing in my Denali will def defeat the purpose of having a 6.2L motor.
I'm also wondering if there is any other product that someone might have that they like.
Thanks
Looks like a steel unit made for contractors that have heavy tools and equipment. The average I get in my bed for a hunting trip across the country is 400-600 lbs . I gave some thought to a slide on top of my drawers (seen it at the L.A. Car Show), but it would definitely be an aluminum lightweight job.
These drawers are 10" high x 48" wide x a little less than the 5 1/2' bed (my current truck has a 6 1/2' bed) and weigh about 200lbs (3rd truck they've been in). Then my topper is another couple hundred. I'm 400-500 lbs behind before I put anything in it.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
