Rims for Lifted Trucks vs Not Lifted
Mikejonce
I was shopping for rims today, and most of the cool ones I want aren't made for my 2014 Chevy Silverado 1500 LT Z71 unless it's lifted. If I do a lift on my truck (which is my plan) how will figuring out wheel offsets be difficult? Will I be able to use my stock wheels (on the lifted truck) until I can save up for some after-market ones, or will they no longer work?
Usually no, unless you have factory 20s, in which case they usually clear the knuckle. The problem then becomes the wider tires rubbing on the suspension at full lock. That's due to the high + offset of the stock wheels. But you can always run some small spacers for your factory wheels, if need be, until you get new wheels. As far as aftermarket wheels go, what's the look you're after? To me, "cool ones unless it's lifted" means you're looking at some wide wheels with a nice negative offset?
I guess...not sure exactly what a negative offset even is! Sorry for the ignorance. I'm currently looking at the Anthem A711's, the Anthem 721 Enforcer's, the Raceline 991C Assults, and the Fuel Krank's. Leaning toward the Anthem 721's though. Can't believe I actually might buy a black wheel! I always pictured going with chrome! At least the Anthem 721's have a couple chrome accents. :)
Im the simplest of terms, (-) pushes out from the truck and (+) tucks in. What size are looking at?
My understanding of "negative" offset is that the hub face of the wheel is inboard of the centerline ("0" offset) of the wheel, irregardless of wheel width. These measurements are given most often in millimeters.
Looking at 20's. But a lot of people are saying 18's are good too with a meaty tire..
It' boils down to sidewall height and what you expect to do with the tires.
- In general, a shorter sidewall will give more precise steering and better on-road handling, but will ride harsher. The wheel size increase will add weight to the tire/wheel assembly, more so than the tire weight will decrease.
- in general, the taller sidewall tire will ride softer and provide less possibility of tire/wheel damage from impacts. Tall sidewalls will also better allow for "airing down" to increase contact in sand or other loose surface conditions.
If you have stock 18s, you can run Cognito UCAs. I don't know about 17s. Call the lift maker.
Thank you Spurshot! I appreciate all your comments. I have the stock 17's on mine. I'm assuming that's your Sierra in the signature. Noice!!! What have you done to it? Any plans to sup-up?!
    appletrav
    appletrav
  • Who's Online   4 Members, 0 Anonymous, 809 Guests (See full list)
