Retrax lock/handle on bed cover is freezing up!
PMattras
With the very cold weather were are having in CT, I have been having trouble with the handle/lock on my Retrax One. It appears the handle/lock is freezing up (very fast) just with cold weather and sometimes when it is snowing (getting wet) etc. I can't close or lock it after I open it up. I put the truck back in the garage and use a hair dryer and I can close it very easy. Sometimes I just notice this with very cold (below zero) with high wind chill factor. Sometimes it is easy to open but I can't (don't want to force it) close it afterwards until I warm it back up. It seem once the inside of the handle is exposed to the cold it is a very fast freeze up.
Anyone having this problem and what can you do about it?
I don't have one of these covers but is there any kind of way to insulate the handle by chance? I know we are having a very cold winter here in Southern Louisiana. Although its not near as cold as what everyone up North is seeing. Coldest we have gotten to is a 9 degree wind chill.
If there is any kind of a way to insulate the handle then I would think that would help. Just the first thought that came to my mind. I'm surprised that Retrax wouldn't have performed tests and figured out a way to prevent this from happening
I am thinking maybe some moisture got into the lock/handle and when it is exposed it could be a fast freeze. Maybe I didn't put the plastic cover on right. Not sure.
My lock froze the other morning. It had some moisture in the lock from rain a few days before. I have used some WD40 to help eliminate any moisture and then applied some white grease to help keep the moisture out. I haven't had to open it in the morning yet so I'll have to wait to see if this helps. I have the Retrax Pro.
Does your hand or fingers get full of oil or grease when you have to open and close it?
Nope. A lite coating goes a long way to repel any water.
Thanks for the tips. I never seen something that would fast freeze like this.
Silicone spray helps as well.
That is what I would try myself.......Now I need to go pick-up a can before mine freezes, lol
I went back to the installer yesterday and he told me to use the key anti freeze. I haven't tried this yet but this morning it was 22 degrees and the lock was frozen. When I put it in the garage to warm up it is okay. Installer told me some people are having this problem around here. It is metal on metal. It is funny because sometimes I can open it but once this is done the lock flash freezes up and can't close/lock it. I have to warm it back up and it opens okay. Very weird because it happens so fast. Maybe there is water in the lock set.
    C. Hart
    C. Hart
  • Who's Online   3 Members, 0 Anonymous, 519 Guests (See full list)
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
    • The Allison 10 speed torque converter doesn't "lock up" like the previous transmissions. It has 4 operational modes; open, slip, transition from open to slip; transition from slip to open. I have an Edge CTS3 monitor and I monitor transmission torque converter slip. Step on the gas and you get a little slip. Take your foot off the gas and you get a little negative slip. I have not found a way to display the torque converter mode beyond that. My Edge CTS3 also displays something that our trucks should already display, the current gear. I also monitor throttle body position and engine load. If I see the engine load getting too high, I'll manually drop a gear.
    • Nice result. Your filter is working well  I'd have like to have seen the acid number for this sample. Curious type that I am.
