LED Blinker
I just replaced my stock front running lights/blinker bulbs with putco plasma led's. Now because of the led's using a lot less power, I'm assuming, the truck thinks the lights are going out so when i turn my blinkers on they flash normal 3 times then they do the high speed flashing and i get a warning message saying i need to service my turn signal. all of this is annoying so i was wondering if anybody knows if its possible to bypass this code or whats the best way to fix this issue? id really like to not have to wire a relay in..
No relays will have to be wired in, although, you will need to wire in a resistor. VLED V3 triton has a built in resistor so that everything is PNP. I changed mine to the V3 triton and I am very happy with it. Never had a hyperlink issue
