Which intake gaskets to use
Well I found out last night that I might have a bad knock sensor on my 99 silverado 2500 6.0. I've already found the fix for that. But question is what brand of intake gaskets should I use? Was considering fel pro always used that brand. But if there's something better I'd like to know. Was looking at the victor reins set on rock auto since it had everything.
I assume you're talking about this set?
http://www.rockauto.com/catalog/moreinfo.php?pk=2648372&cc=1412086
That wouldn't really be needed if you're just swapping knock sensors... That includes all the gaskets for removing the valley cover (which you wouldn't need to do) in addition to the intake.
If you're shopping at RockAuto... This would be my pick, OE like newdude said.
http://www.rockauto.com/catalog/moreinfo.php?pk=2005576&cc=1412086
Any advice on cleaning out the manifold after I get it off? Oh and I thought I read something about having to replace manifold bolts after taking it off, is this true?
No need to replace the intake manifold bolts. GM recommends using blue Loctite on the threads, and there is a torque pattern and its a two step torque sequence.
Tighten intake manifold bolts first pass in sequence to 5 Y (44 lb in).
Tighten intake manifold bolts final pass in sequence to 10 Y (89 lb in).
I used B-12 Chemtool to clean mine as well as the throttle body.
I also took some time to CAREFULLY clean out the intake runners on the heads.
Runs like a champ!
    ballencd
    ballencd
  • Who's Online   4 Members, 0 Anonymous, 459 Guests (See full list)
