Zach1990's 2004 GMC Sierra 2wd
zach1990
  • Replies 334
I didn't see one on that website. Carid has them for close to that after the core return plus the trans temp with it
All 3 you mentioned. Summit didn't have one with trans temp
If you looked at pickup salvage, give them a phone call. They arent great about updating the site. 8 am pacific is when they open. They are local for me and ship nationwide
Scangauge 2 mounted to the dash. The inside needs more of a power washing right now. Don't think a good scrubbing will clean this joker. Doing front brakes today also
You seem pretty set on them. Would you also suggest them for other parts I may need in the future too? Just curious...
I would. Usually if it is a stock part, they are my first stop. But they are local, but also one of the few late model pickup oriented salvage yards in the country. They only do trucks and jeeps
Why not put the scangauge in the center console? Or do you have the split bench?
Its got the same split bench that my regular cab has.
On that note I'll post pics of the inside when I finally get it cleaned. Its a royal mess. The inside was never cleaned in the 10 years my dad had the truck.
Since last night I've been getting a P0300 when idling along with the noise. This may be more of a PITA than I originally bargained for
Got these for free to cover up the terrible bed rails9129042f83a30be7e05f9bf793780ef5.jpg
Local parts store was out of tape so hopefully this holds
40781c9aa0f955da05bd5ecba84b75ce.jpg2c5691a982b3fdcfa6b095aeb4a5b12a.jpg7a8e1c760e2263800100f6c4bfc5119b.jpg
Got to see what kind of highway mileage this truck gets. Its a far cry from my old one. This is from El Dorado AR to Ruston LA
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,307 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
