Zach1990's 2004 GMC Sierra 2wd
zach1990
  • Replies 334
Air filter can be added pretty easily.
How so?
Got the tune up done and boy was this thing bad. Never had a plug and wire change in 333k miles. Getting the old wires off was terribly hard. She runs better now but I found a few more problems. Truck has an oil leak, appears to be the rear main seal and it's not a slow one either. Also getting a P0300 random misfire. The driver side catalytic converter is clogged up so maybe fixing that will help. We shall see. Got a long ways to go
Found a few more problems changing bulbs today. My 2000 did the same thing. Not sure what the problem is
Turn signal smoking and glowing
Rest of the light sockets burned
Spent some time on the truck today. Got all 3 lower lights on the passenger side working again. Need to replace all 3 sockets on the driver side. Also changed my lights to 4 low/8 high but planning on changing the DRLs to amber when I fix them and wiring them to stay on with the headlights for a cleaner look. Also put my chrome bars on to hold down the rail covers since my glue didn't hold up. Its easier on the eyes than my destroyed bed rails.
I think i have a write up on my amber stuff on here or in my build
Thanks. I'll hunt it down
It will either be in how to or the 800/900 section
Yea, I just used google to dig it up
Also do you have a write up or know of one for the big 3 upgrade you did?
    Smitty462
    Smitty462
  • Who's Online   6 Members, 1 Anonymous, 686 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
