Zach1990's 2004 GMC Sierra 2wd
zach1990
Cleared some newer headlights I scored for free to replace my scratched up ones
  • Replies 334
Got lucky and found a box. By the way the final mileage count was 5,4xx on them.
Awesome I'm dying to get them. Believe me May 8th can't get here fast enough! How hard are the shocks to install on the 2 wheel drive since I assume u have to go up and in? Will be doing it without a lift
336k miles, misfiring at idle, and clogged cats and still manage this kind of mpg on long trips. Was 22.2 when I pulled in my parents house 100 miles down the road. I'm really hopeful it's still 20 plus after the lift and when I repair the problems
Stands and a jack
Yeah i did mine in about 1.5 hours, its not bad at all. The rears could be done in 20 minute! The most time was spent up front because I couldn't loosen the front nut.
You need allen wrench, regular wrench, and socket.
Haven't done anything recently except clean her up real good. More mods to come soon
More to come. What happens in about 2 weeks?
With my schedule idk when your old suspension will actually get put on here. Gonna do it asap tho cause these stock shocks are completely blown
It will take about 5 business days to get there.
But it will look good leveled and with 2" blocks.
The blocks are not going in till I get spindles and tires. That's gonna probably be a project for next year
Shocks shouldnt go in with out level and blocks. They are longer than the 2wd shock
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,260 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
