Zach1990's 2004 GMC Sierra 2wd
zach1990
Shocks shouldnt go in with out level and blocks. They are longer than the 2wd shock
Rear won't work without blocks?
  • Replies 334
The rear is the size for the 4wd
So in other words will be too compressed without my blocks?
You can try. But they were stock replacements for 4wd. Fronts need the lift and they are like .75 too long still.
I just want a smoother ride. This thing is terrible on the country roads I live down. BAD!
Like my wife gets nauseous riding in it
Got home from a structure fire to find this on the porch. Thanks Chris!
Bilstein 5100 shocks and 2" leveling kit
I thought they would take a lot longer to get there. I didnt ship them until after lunch on Monday.
I was impressed. They are just sitting in the back seat until I can find enough time to put them in
Level it and block it. It will look good like that until you get the spindles
Chris roughly how long did the instal of all this take you and how far off did it throw your alignment? Thinking I may throw it on here soon and get an alignment in a couple weeks since it looks like a need a few balljoints. I am taking it on a 5 hour round trip tuesday
Pulling them out, less than 3 hours wheels off to wheels on
Get it in yet?
dfb440223dfbd5a8a7b9f3628806a960.jpgThats what a garage is for and charge your damn phone
Don't have access to one and been busy
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
