Zach1990's 2004 GMC Sierra 2wd
zach1990
But then again could that be the hub leaking grease out of the back of it??
  • Replies 334
So the squeaking has been diagnosed. Post ball joint failure that is
Well she'll be sitting until I can put it together again. Here lately it's done nothin but piss me off
Well the old gal is fixed and on the road again. Hopefully I will be addressing the exhaust issues next. Catalytic converters are clogged up bad. Looking at either a bolt in replacement or going to the shop. Either way seems expensive. If anyone has experience with this feel free to chime in.
Seems like your having a lot of issues with this truck, you never seemed to have as many issues with your old reg cab
My dad used it as his work truck (construction work) since it was new. Its been used hard but I'm hoping to turn it into something to be proud of. The last one was just one hell of a truck. Was very pleased with it for sure
For your cats, cheaper would be a shop welding some in. You can buy magnaflow bolt ons which come with a new Y pipe
Just realized I never posted an after lift picture
The more I see trucks like this, the more I want to do it
All i know is it has Notto 420S tires
Man you guys are rough lol
Bad day for my center console. Need to find out if I can replace just the lid or what needs to be done
Don't feel bad! Same thing happened to me.. Hyper extended mine.
If I had a 2wd truck I would lower it!
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
