Zach1990's 2004 GMC Sierra 2wd
zach1990
About 8 months
Why 8 months? That's not in line at all with the online reviews I've seen...
Sent from my XT1080 using Tapatalk
  • Replies 334
My right sides went bad first. Then i got 20's with coopers. Then my goodyears have so far given me over 35k and counting
Well I tried running the tires I had till I could save up enough for something good that I really wanted. $800 budget with no choice since 2 are now showing wire. Got to get what I can and the reviews for them have been great minus your experience....
Got the Firestone's this morning. So far I am very pleased with them. I'll update with pictures later when I can get time to clean it up.
My dad has what I believe to be the same tire for a year now and they are doing quite well regarding wear. His '06 is a 4x4 but he hasn't "needed" it in snow, mud, or even sand with these firestones.
Although he paid $400 for them in practically new conditions along with coming mounted on the OEM '06 alloy wheels.
Good to hear!
Coming along
^^ That shine!
Only at a distance lol
  • 3 weeks later...
I've come to a crossroad with this truck. It is now leaking/consuming oil at a rate of roughly 10 quarts per 4 weeks. The rear main seal is the worst culprit. Plus she ticks loudly non stop. All thing aside she still runs very strong. Had her cruising down an interstate at 80+ with no problems the other day. I'm just undecided as to how to continue at this point with almost 350k miles on her.
That is not acceptable imo. Get it looked at by a trusted shop and probably end up getting a new used 5.3, i don't think it's logical to fix at this mileage.
And the ticking is more than likely caused by the oil pump gasket/seal. No biggie.
And I'm very sorry about your situation, I doubt it's an easy one. I wish you the best of luck.
And may be you should ask Daryl for his thoughts on a new engine... :)
I say all the time that I want to 6.0 swap. It'll all boil down to funding
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,260 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
