Zach1990's 2004 GMC Sierra 2wd
zach1990
Junkyard 6.0. Thats what i did. I didnt buy a new or reman engine. I found a junker frim a wrecked 05 Escalade with 55k
  • Replies 334
So down the road cost for engine, trans, and tuning how much would you say you spent?
Sent from my XT1080 using Tapatalk
I didnt buy a new trans. I had the swap done. The shop knocked it all out in 2 days and $3000 out the door. Paid $1500 for the engine and had the vette 2nd servo installed in the trans. They also dyno tuned it but had black bear rework that
Gotcha mine will need a transmission as well. I'm actually shocked that the factory one is still kicking as well as it is. Anyway in my opinion no matter what I do I'm going to wind out financially on top if I just do an engine/trans swap. Paid cash for my last truck and kept it 7 years then traded (no money involved) for this one. I'd like to continue on the no payment route lol
Got a chance to try a bully dog gt before deciding to buy. It would be basically half off if I do. So far I'm pleased. Running the 91+ octane performance tune with performance transmission settings and even though it's not a huge gain the truck does drive better. I'm back to factory gas mileage with my bigger tires, I love how the transmission feels now, and the acceleration just driving normal feels more responsive. I may just keep this thing
The Bully Dog unit is here to stay. The truck is more responsive now and shifts much better. Plus I averaged 22 mpg hwy on a 250 mile trip over Christmas and 15 mpg city so far. I wouldn't recommend full price for this unit, but for what I'm given its worth it to me (next to nothing btw). Also the truck seems to need a new alternator. It's only holding 13 volts at best. That and a new belt will be going on this weekend. Plus I spent a little time cleaning up the engine bay today. Looking good for its miles.
And heres a quick shot of her with a storm coming in the background. It's the only break in the rain we've had since I waxed and detailed her the other day
Got a new serpentine belt and a headlight alignment today
What do you mean by a headlight alignment? Did you do it yourself against a wall in the dark?
Yes. First time its ever been redone on this truck
I don't think I've ever realigned mine. They seem to have held position. I've never replaced a low/high beam either, need to figure out what they are and get the same thing next time. >50k out of a set of bulbs isn't bad in my opinion.
Sent from my SM-G920V using Tapatalk
Did the belts on mine a couple of months ago too. Had a MotorVac done and got back 1mpg and much smoother acceleration response.
Never heard of a motorvac. What is it?
Better than I've ever got!
  • 3 weeks later...
I was driving home doing 65 mph on the hwy when the truck flashed reduced engine power and threw a P2008 code. Idk what caused it yet, but I cleared the code and drove it 10 more miles home at 60 mph and didn't have another issue. Guess I'll get around to diagnosing this soon.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,260 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
