Zach1990's 2004 GMC Sierra 2wd
zach1990
Well the old gal got some loving today. New radiator, upper and lower radiator hoses, thermostat, oil change, and all new coolant. Also threw in some Lucas injector cleaner.
The crack in the old one
And I need to find something to clean up this nasty engine bay
Sent from my XT1080 using Tapatalk
  • Replies 334
Holy cow that is nasty! lol
But kudos on all of that maintenance. It looks like we're using the same oil too.
Going to clean the throttle body this evening since I noticed it was so gummed it that it wasnt closing correctly. Anyone care to chime in about whether or not it's safe to actuate it and clean it with it on the truck? Haven't done it on the newer nbs...
Ive held it open and cleaned on 2 different trucks. Didnt hurt anything
Didn't figure it would, but felt it safer to ask lol. Was hoping that would finally solve my rough idle and random misfire I've been trying to hunt down since I got the truck. O well, gonna try o2 sensors here soon and see if that helps. If nothing changes I'll be getting an exhaust put on next week. I've pretty well decided I want to remove the y pipe and do a di/do Flowmaster 40 dumped over the axle with 4" tips.
If you have a misfire I wouldn't spend money on exhaust. Especially a blomaster :jester:
At this point I'm convinced it's an internal issue so I'm just gonna save up and eventually put a new motor in it. Never been a big fan of flowmaster but I found a few videos on youtube of them di/do with no cats and I love it. It's actually the only muffler I've found that sounds good without cats. Hell the stock muffler sounds like you are blowing over the top of a soda bottle now without the cats.
Are you still on the original tranny? If so then add one to the near future shopping list too.
I too don't see hwhy you would get an exhaust if the engine isn't near 100%.
Yes it's still the original. Just building it the best I can with a small income. I'll keep the motor up as best as I'm capable and just get a used one dropped in if/when the time comes. She burns oil and misfires at idle but still gets roughly 21mpg hwy/ 16 city. Does great for what I need. She'll do for now.
Took the truck on a long drive for my anniversary. In 2 days time i will have put close to 500 miles on the truck by the time I get home tonight. Driving everything from flat highways to busy cities to hilly mountains. Will update with numbers tomorrow, but so far the old beast is doing great!
Truck did amazing on the trip for its age and mileage. Felt nice and strong pulling small hills but had to be down shifted to feel comfortable climbing steep grades. The ride was extremely comfortable with the new shocks (thanks again Chris) and it did great on fuel as well.
Anyway here's the numbers I gathered using the DIC and scan gauge:
Final mileage: 342,684
Miles traveled: 460.9
Total fuel used: 24.1 gallons
Avg MPG for the entire trip: 19.1
Best HWY mpg noted: 21.8
Best CITY mpg noted: 18
Avg Engine Temp: 205-210
Transmission stayed 100-110 above outside temp
The truck did throw the P0300 a few times, but as usual was not enough to even notice other than the annoying blinking light. Also threw a knock sensor code so those will be up soon as well.
All together I couldn't have been more pleased with this thing. If it keeps up and my plans come together for it the old gal may be around a long time.
Use fuel log. I love it. My mileage is low because i spend about 30 minutes idling with AC on before class every day.
Just to update the to do list also:
(This is in no particular order)
* O2 sensors
* knock sensors
*Exhaust
* Airaid Jr MIT
* new front windshield
* front end alignment
* 3" RC Spindles
* 3" rear blocks
* 33" tires
* valve cover and head gaskets
I'd also eventually like to replace the motor and transmission as well as get a new paint job, but theirs no telling when or if I'll be able to afford all of that. We shall see.
How was the drive with level and 5100's?
It was very smooth. Rode better than most vehicles I've been in.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 545 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
