Zach1990's 2004 GMC Sierra 2wd
zach1990
Your the man Chris!
I aim to please
  • Replies 334
How so?
If you look at the hvac under the dash, near the "resistor" there is an outline of where the filter access door would be. Also a slot to put the door on one side and a hole for a screw on the other. You have to drill and dremel out the opening without hitting the condenser right next to it. :)
I may look into this. I know the filter on my 2000 saved a BUNCH of dirt, leaves, etc from going in my air conditioning. Changed it yearly and it was always clogged up or close to it
I just wish they had it under the hood like the cars did... Takes about 30 seconds to change it there.
Picked up the socket for the driver side turn signal. Will replace the other 2 later when funds allow. Also planning to paint the radiator core support today
Whole thing or the bar i painted that the trans cooler mounts to?
Gonna pretty well be the same as yours. Bought cherry red paint weeks ago just haven't done it yet
I completely sanded, used Rustoleum self etching primer, then Rustoleum 2X Apple Red, then hit it with clear. Actual coat numbers are in the build
I don't remember what I bought but it's the same self etching stuff I bought last time and it held up great
Got the turn signal and DRL sockets fixed now just need the small parking light. Also painted the core support tho it's barely noticeable until I swap grills later on
Thanks bud
No Problem. I love these GMT800 trucks. I'm enjoying all of our builds for them on here a lot!
Your's and Chris's build threads have personally been my research haven since y'all have been at it a little longer lol
Glad I can be of some help lol! My build is basically building a new truck!
    Smitty462
    Smitty462
  • Who's Online   6 Members, 1 Anonymous, 686 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
