Zach1990's 2004 GMC Sierra 2wd
zach1990
It's gone atm after adding some risalone but I will look into it. Thanks
  • Replies 334
Got to see what kind of highway mileage this truck gets. Its a far cry from my old one. This is from El Dorado AR to Ruston LA
You think you're hard with 20 MPG?
Best driving of my life just to test it lol
You got to get get those single digits
My old truck averaged 11 and that's 85% highway
Wow! I thought 12 was bad.
Well it was a 333k mile 4.8 with 3.73 gears, 4" lift, and 33x12.5s
I figured it was because of the lift and tires. Didn't know it was a 4.8L
Got the front brakes replaced, greased everything with a fitting, rotated tires, checked fluids, and cleaned the air filter.
Next on the to do list is the rear brakes then a motor flush plus oil change. Then a full tune up. Hopefully all of this will happen in the next 2 months at max.
Ran rislone in it for a week then used a motor flush today before changing the oil to 5w20 Mobile One with a Mobile One filter. This old thing will probably use the hell out of this oil but it's worth a try
Also have NGK Plugs and Duralast wires to go in it tomorrow if I get the time. This thing idles so rough that I just skipped straight to the tune up process...
Does this truck have cabin and fuel filters? I don't know if GMC had the same changes as Chevrolet.
Same changes. It is an 04 so no fuel filter and no cabin filter
Unfortunately Chris is right. I was a little bummed out about that
    RangerRick17
    RangerRick17
  • Who's Online   5 Members, 1 Anonymous, 608 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
