Happy Birthday
MountaineerTom
Happy Birthday :eek:
(I still don't know what the text is about, but I'm partial to the red and blues of course)
The dupe means, when someone makes a post that someone already posted that is called a dupe.
Oh and Happy B-day Stepside.  Have a cold on on me.  :chevy:  :cool:  :flag:
    Policeoff01
    Policeoff01
  • Who's Online   3 Members, 0 Anonymous, 719 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
