Radar detector hard wire question regarding drivers side fuse box
Don't mind the dirty ass interior
Awesome, if you have a chance can you post a pic of where you mounted the remote
Sweet, thanks! Did you pull the dash down to get the remote there or just feed the wire through to the under side of the dash?
I pulled the lower panel down.
Any screws or anything need to be taken out or do you just yank down on it?
I don't remember any screws. It uses clips that snap into the dash.
I can't find the size of the female wire disconnect that fits the existing RAP connector? Do yall know what size female end is needed?
k2-_214d382c-daa7-4697-821d-2c83f4594868
In case anyone was following this, I tapped into the RAP that is listed in http://www.gm-trucks.com/forums/topic/155775-2014-rap-retained-accessory-power/?hl=rap, I had to cut off the T-tap wire connector that was originally on the Passport hardwire kit. I then attached a .110" 22-18 gauge female disconnect to the end of the wire and it fit perfectly on the chevy RAP area. I then ran the wire up the A pillar, tucked it behind the headliner, then down the mirror to a windshield mount. Thanks to everyone for helping out.
