ring gear
how to tell what size ring gear is in my 1999 silverado without pulling the cover. the reason i ask is i need to do my pinion seal and i see an 8.5 and a 9.5 inch ring gear listed
Lol you know what I meant!
Idk why some places label it 8.5" when it's an 8.6" cause GM did manufacture 8.5" for some cars back in the day
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,194 Guests (See full list)
