I want to install a trailer brake controller on my 2014 GMC Sierra 1500 SLT Z71 with the 5.3, it has the 3.42 rear end. I like the looks of the factory brake controller (mine does not have it) and I would like to go that route....do you know if the factory wiring is located behind the panel where I can purchase the necessary controller and dash molding and install a factory brake controller?
I did a search for this topic and did not see this come up anywhere else.
Any info would be helpful.
Thanks,
Saldog
I think this will be another SLE headlights to slt headlights dilemma but could be wrong but I wouldn't be surprised if it involved lots of $$
If I understand you correctly, it cannot be done.
Subject: Adding Integrated Trailer Brake Controller RPO JL1 999999995.gif Models: 2014 Chevrolet Silverado 1500 2015 Chevrolet Silverado, Suburban, Tahoe 2014 GMC Sierra 1500 2015 GMC Sierra, Yukon Models
This PI was superseded to update Note section. Please discard PIT5241A.
Some customers may request the factory Integrated Trailer Brake Controller (RPO JL1) be installed on their Full-Size Pickup or SUV when the vehicle was not ordered with the option.
This is to advise you that - if the vehicle does not have the option (RPO JL1), it cannot be added to the vehicle.
Edited by tbarn
Correct, it is not possible on the K2xx trucks to add the factory trailer brake controller. You can get the harness from GM at no charge that allows you to run an aftermarket controller instead.
it is because it will require BCM programming that GM no longer allows the dealer to make changes to.
This is the way it was in the GMT-900 too iirc.
The wiring is there though. If you want to work with some aftermarket BCM programming folks to see if they can enable it... but there's no guarantee it's ALL there.
Don't know that GM can no longer re-do the BCM. Just a few weeks ago I spoke to a dealer who said they could reprogram my BCM to accept factory fogs despite there being no RPO for them on my truck.
Note the top harness plugging into the empty pocket where the switch goes.
I know you posted that up, but that dealer is smoking it and doesn't know it yet. I am on a really good basis with my dealer, they called the GM place they deal with. GM will not change the programming of any module for your vehicle for any features you add that your truck did not come with from the factory. Back on the GMT900 trucks you could use the VIN from a truck with the option and use that to flash your BCM, cant do that on the K2xx trucks.
When they plug in the laptop to your truck they have to put in your VIN, the system checks to make sure the VIN inputted matches the VIN in the module(s). If they don't it will not go any further in the process. once the module and VNI is verified then they can flash the most recent update for that module for your VIN.
Chris explained it awhile back as to why they do it, I don't remember the full explanation. GM is closing the loop holes with each new generation, before long GM will have it to where you cant even tune the vehicles if they have it their way as will other manufactures.
Well, in the case of the trailer brake controller, you're probably not dealing with something traditional here, so much as you're dealing with an interface into a complicated system. The stock controller probably integrates into existing hooks for wheel speed, brake pedal pressure, speed, etc. So the chances of "going around" a locked out BCM won't work either.
The guy I spoke to at the dealer told me he had called GM "techline." The process he described was to plug the laptop into the truck, get techline into the laptop and they would "take over."
TBH you're probably right, but this is the process I was given, and I honestly didn't believe him, which is why I asked twice. He swore they could do it.
Edited by darkfox1
it would be great to see that, believe me. only one way to find out is to become a guinea pig and try it though. I went the opposite way, I wanted to remove my brake controller as I don't need it and wont ever use it, I bought the other trim bezel to even get rid of it. I unplugged the controller and as soon as I fire the truck up got a warning of brake controller failure and to see the dealership. Came on at every start up.
I remove the main switch from the trim ring and stuffed it back into the back of the dash out of the way for now.
You really find the small cubby hole of the other trim bezel useful enough to remove the trailer brake controller? I actually had to re-read your post because I cannot understand a situation where removing the controller would make sense.
Yep, for me it was. I have/had absolutely 0 need, want or desire for the controller on my truck. I had no other option though as the dealership I got my truck from ordered all of their trucks with them no matter what. So unless I wanted to place a custom order and wait 8-10 weeks at the time then I was stuck with it. I will never tow anything that has a braking system on it, I use the truck to drive back and forth to work and make sure I can get here in any weather since I am an essential employee to keeping the electricity on for people.
The most that ever goes in the bed is our bicycles for races or stuff we need for the house, sometimes we use the receiver hitch bike carrier as well.
When I bought the other bezel I thought the cubby would be bigger, so yeah it doesn't get much use but I like it better for some reason than having the controller sitting there instead.
Sure would be useful to have..
I wish my truck came with it.. (and the 3.42s to actually pull something...)
Sadly.. the random used truck on the lot didn't. :lol:
This bcm lockdown thing kinda burns my bacon a little bit. If I wanna put GM parts on my GM truck and have GM install the accessories, what's the problem? Why be a jerk about it? I mean I'm spending my money elsewhere here.. it's not like someone other than a billionare's gonna go "WHELP, time to trade the truck since it doesn't have a brake controller!" GM is LOSING MONEY with this approach.
    Afennell19
    Afennell19
  • Who's Online   1 Member, 0 Anonymous, 928 Guests (See full list)
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
