Put myself in debt for another 4 years
k1500chevy97
Felt sorry for GM because they are losing a lot of sales so I gave them one
Went down today and got suckered into signing papers for a new 03 z71 extcab LS arrival blue
I still don't like the way this front end looks on it :crackup: (gonna have to find out if the 02 style will fit ) The interior is much better than our farms 02 silverado LS .
Pics to come in picture post
Congrats on the new truck.  Sort of surprised because you were the one griping the loudest about how ugly the '03 Chevys were.  :banghead:
Well, first, congrats!   :thumb:  I think you'll really like what it has to offer and eventually be able to put up w/ the nose clip!
Now, with all due respect, what with all the negative carrying on about them, I thought you'd be the *last* person on God's green earth to buy an '03 chevy!!  :banghead:
Seriously though, enjoy!  Nice choice in color too! :smash:
P.S. - What to you think about that fugly "door" molding?  I may post pics w/ and with out it (photochopped) and have a poll to keep or take off.
I think we're going to keep the molding on just in case someone decides to swing their car door open while parked a lil too close to it  :banghead:
I agree. I pulled all of it off of my 92, and while I like the way that it looks without it...I have spent several hundred bucks over the years on paintless dent repair.
It stays on both of my 02 trucks. No matter how much I don't like it.
Sweet truck though. My next truck will be that color.
Congrats!
They look better tome now than they did when they first ame out.  :thumb:
I  hope it breaks  down on you so  you'll learn to appreciate and respect the '03s.  :smash:  :banghead:
Well, I am suprised.  Congrats on the new truck.
surprised doesn't even cover it...  For a guy who bashed the 03's in every other thread.... okay, probably more often than that, I never thought I'd see that day
Congrats, even if you think it is  :banghead:
Deep down inside you must not have hated it as much as you said.
That's my ONLY positive reason for not ditching them, too! :smash:
Congrats on the new truck. I wish all  the best with it. I like the look of it. I guess I'm in the minority. Enjoy it :thumb:  :thumb:  :thumb:
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
