transfer case operation
Ok , took the truck out today for a little offroad . I tried to put it in 4L but it wouldnt go in , instead it went into N and I couldnt get it out until I shifted the tranny to N .
So can someone explain the operation of this tricky thing to me ???
In my 97 I can go through the transfer case smooth with the clutch depressed and or the tranny in neutral
To go in to 4 lo,you are actually supposed to be either stopped or barely rolling (preferred method) and have the transmission in neutral.
No offense, but... What were you thinking trying to get it in 4 lo without the tranny in neutral?
If the truck is not moving and you try to shift into 4 lo, you will hear some 'grinding' noise.  Don't worry: the noise is normal.  Even if you have the auto shift, you'll still hear a nice clunk as the gears fall into place.
Just remember, before going to 4 lo, put the beast in neutral and have it slightly rolling, then "firmly" push the manual lever all the way forward into 4 lo.  You do not have to be in neutral in order to go into 4 high -- just don't try to go into 4 high at 60 mph.
Good luck!   :banghead:
No manual lever in these trucks.
Actually, they still offer the floor-mounted levers.  Obviously not available if you have the full console/bucket seat combination.
K1500 has the lever as seen in one of his interior pics.
Umm....yup, you are right.
I'm a  :smash:
:banghead:
Actually, on the newer models, it doesn't matter what speed you are going when you shift into 4H.  This is only for the automatic transfer case, I am not sure about the manual.  4L is a different story - put the truck in neutral, have it rolling 1-2 MPH, and hit the 4L button.  It will take a few seconds and you will hear a cluck.  Same procedure to get it out of 4L - just have the truck in neutral.
    2022LtTbZ71
    2022LtTbZ71
  • Who's Online   5 Members, 1 Anonymous, 1,273 Guests (See full list)
