Which is longer?
JonesNTN
Which is longer?
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Jimminy Christmas! :banghead:
I'm contemplating the next poll I'm gonna make.
It's a toss up between "Howoften do  you shower?" and "How often do you change your underpants?"! :smash:  :smash:
Its is a result of a constant debate between me and my wife. I call her a weirdo because her second toe is longer, and she is saying that I am the oddball. I have seen polls where the actual is 50-50, but I just need some ammo. :banghead:
Same boat here!
my gf makes fun of me  :smash: and says all my toes are long.  My second toe (next to my big toe) is the longest of them all
guess im a wierdo or a  :smash:   (probably both) :banghead:
my gf makes fun of me  :jester: and says all my toes are long.
Yeah, well she's just jealous that she can't pick up objects with her feet, she has to bend all the way down.
I've got long toes too, comes from my dad's side of the family, not like it's that noticeable though w/ size 14 feet.  But, I'd have to say my first and second toe are roughly the same length, the first toe may be a hair longer.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
