is there a way to set the TPMS sensors to accept a diff pressure rating? I changed my stock tires out when I lifted my truck and the TPMS warning drives me crazy!
Some here have said the dealer can chage to original settings ...
I am willing to bet the dealer can change the TPMS setting, but not many of them will. All that liability nonsense. After not getting any dealer to take the "risk", I just inflate the tires to what I want and dismiss the the DIC TPMS warnings and go about my business. Have grown comfortable ignoring the little tire pressure light on the lower right of the gauge cluster. The only thing I use TPMS for is monitoring the pressures and seeing that they are where I want them, along with good 'ol fashioned manual checking occasionally with a gauge.
I've still got the stock tires on mine and have adjusted the air a few times to see what rides the best unloaded and keeps the light off. So far, keeping 60 psi in front and dropping the rear to 65 psi seems to be okay. When the rears get close to 60, it trips the TPMS warning. I've not dropped the front much below 55-60, so I can't speak for their threshold.
My 2015 starts having a fit whenever tire pressures are more than 5 psi from the stock factory TPMS settings. I just ignore. I generally run about 55 psi all the way around when not hauling or towing heavy. I picked that pressure as a balance of tire wear, ride, and traction.
I run my stock 15 SLT HD at 46 Front / 55 Rear COLD and no dash lights on !
side note
Last week I set the above tire pressure at 40* F sitting cold and today it hit the mid 60's and my tires read 50 / 60 psi HOT (after highway travel - amazing how the temp & use push them up ...
Im pulling a 5000 lb trailer to but i slowly dropped mine from 80psi to 55psi all around. It rides just right now with no tpms warning.
    1981dustin
    1981dustin
  • Who's Online   2 Members, 0 Anonymous, 1,543 Guests (See full list)
