Bed Covers
I'm sure many topics been covered on this. I own an Avalanche and like most Avalanche owners, we have been spoiled to the bed covers. Well, It's time for me to step up a "real" truck, Sierra 1500, and looking to get a high end cover.
So far, seems like the Diamondbacks are one of the best in the market. Any others I should consider?
Retrax
I'll never get another truck without one.
Get the aluminum one not the plastic one.
Pricey though but sharp looking, most durable, water tight and did I say sharp looking?
Search the thread under my name, I have thread on retrax with pictures from photobucket link
GOT BOOST ?
I am a former Avalanche owner as well. I got the gmc soft roll up tonneau. I like that it takes up essentially no space when roled up. My bed is empty 90 % of the time and when it isn't i am hauling something from one place to another. I was getting tired of removing the covers from the avh most of the time I needed to use the bed.
My Diamondback HD is by far the best cover I've had. The ability to haul on top is just something the others can't offer. It's like doubling your cargo space and with the short box it's that much more useful.
Sent from my iPad using Tapatalk HD
Also upgraded from an Avalanche, you're making a good choice. Lol.
I went with the fold-a-cover g4 elite with the personal caddy. Gives me ~75% of my bed when open plus enough room under the caddy that I can get 4 or 5 sheets of plywood in there if I need to. The personal caddy has essentially replaced the Avalanche's storage box things for me, but holds much more. Love it.
Side note, the caddy is much more durable than I thought it would be. I was hauling 8 huge 12-volt batteries the other day and there was an accident in front of me so I had to slam brakes. The straps tying the batteries in place busted and they all slid into the caddy. Just a few dents that can't really be seen. I thought it was going to be crushed.
I was going to buy a Fold-a-cover, but now I'm leaning toward a Peragon.
After more research, I feel the Diamondbacks are the toughest covers in the market. I like the idea of the HD, but not sure if I have that strong of a need for one. Thinking I'll take the money saved buying the SE and get the storage bins. Really going to miss that option from my Avalanche.
I saw an Avalanche concept they did on the 1500s, with the covers and storage. I'd pay the extra $$ to have it.
Are you looking for a cover for the Avalanche? I am confused.
No, I'm trading in the Avalanche for a Sierra 1500. My mind has been set on the Diamondback covers, but wanted to see what other options that are out there.
Check out what the dealer sells. I bought mine with the truck says GMC on it 14 months no leaks. Hard tri fold with soft over laid. Worked it in with my deal payed next to nothing for it.
If you're looking for a high end cover, check out Pace Edwards. I have the remote activated Pace Edwards Bedlocker. I love its low profile and the ability to stop the cover at any point instead of the predetermined spots like other covers. I would say its only downside is its price, other than that its all good!!!
Had to make my cover decision a few weeks ago and went with the diamondback se in black. Love the ability to open front and rear of cover. Plus you don't see that many around
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
